- Thank you received: 38
Kz440 1981 just won't rev!! Please help
- sbc1320
31 Oct 2013 11:47 #611727
by sbc1320
Cool, hope you do a light hone job on those cylinders.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Kz440 1981 just won't rev!! Please help
martinh wrote: After striping the top end of the motor down I found that both top piston rings had worn berry thin and had broken up!! Luckily the bores are still unmarked. Once I fork out for a replacement set and fit them I'm hoping that my problem will be solved.
- martinh
31 Oct 2013 12:58 #611729
by martinh
Replied by martinh on topic Kz440 1981 just won't rev!! Please help
Will do. Do you think this could be the answer to my problem?
- sbc1320
31 Oct 2013 13:32 #611731
by sbc1320
Sounds like part of your problem, hopefully all of the problem. Good luck with it and you will find out when you fix it.
martinh wrote: Will do. Do you think this could be the answer to my problem?
- martinh
05 Nov 2013 16:10 #612184
by martinh
She is alive!!!! Time to get this thing back on the road
- sbc1320
05 Nov 2013 17:12 #612188
by sbc1320
That's good news and a great feeling on your part, congratulations.
