Needle jet installation
- bemoore
28 Oct 2013 18:49
I pulled all the needle jets from the VM carbs on my 650. Now, I'm having trouble getting one them to go back in. Any tricks of persuasion you guys would care to share? I haven't tried mixing and matching them yet. I wanted to keep each jet with the carb it came from, but I may try swapping them around. Should that cause any fueling problems?
77 KZ650C1 w/Kerker 4-1
- kaw-a-holic
Re: Needle jet installation
28 Oct 2013 20:40
That's odd it should slide right back in. Can you provide any pics of the issue?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
29 Oct 2013 02:45bemoore wrote: I pulled all the needle jets from the VM carbs on my 650. Now, I'm having trouble getting one them to go back in. Any tricks of persuasion you guys would care to share? I haven't tried mixing and matching them yet. I wanted to keep each jet with the carb it came from, but I may try swapping them around. Should that cause any fueling problems?
Am thinking -- but not positive -- that the needle jets are a press fit into the carb body , and that a wooden dowel might have been used to drive them out.
In any event, could leave the jets in the refrigerator freezer for a few hours, and attempt to reinstall them while they are "frozen."
- bemoore
29 Oct 2013 04:18 - 29 Oct 2013 04:19This is correct. For the others, I dropped the needle jet into the tube it goes into, then pushed it in with the emulsion tube, which screws in. I usually just work the emulsion tube around a little, and the needle jet would eventually get properly positioned so that I could push it on in with the emulsion tube. I tapped them out using a drill bit.Patton wrote: Am thinking -- but not positive -- that the needle jets are a press fit into the carb body , and that a wooden dowel might have been used to drive them out.
Good idea. I'll give that a try.Patton wrote: In any event, could leave the jets in the refrigerator freezer for a few hours, and attempt to reinstall them while they are "frozen."
Last edit: 29 Oct 2013 04:19 by bemoore.
- boatdrinks
29 Oct 2013 05:17
Sorry I didn't reply back yesterday. I wonder if on that carb body there may be a slight burr on the lip or inside the hole where the jet goes. They usually just pop right in.
Charles
Madison, AL
1978 KZ650 B2A, Luminous Dark Blue
Madison, AL
- Motor Head
29 Oct 2013 05:57bemoore wrote:This is correct. For the others, I dropped the needle jet into the tube it goes into, then pushed it in with the emulsion tube, which screws in. I usually just work the emulsion tube around a little, and the needle jet would eventually get properly positioned so that I could push it on in with the emulsion tube. I tapped them out using a drill bit.Patton wrote: Am thinking -- but not positive -- that the needle jets are a press fit into the carb body , and that a wooden dowel might have been used to drive them out.
Oh you could have damaged those jets doing that. Mushroomed the tops, possibly the tightened the jet hole itself. That Brass is real soft, using steel agaist it and tapping with a hammer would be not recommended.
