- Thank you received: 30
1988 kz1000p carburetor flooding
- jakedude
I have rebuilt several carburetors in my day and never had this problem. Any help would be appreciated.
Nothing lasts, nothing is finished, and nothing is perfect.
- Thank you received: 2098
If not, new float valves may already need re-cleaning.
- jakedude
Keep the ideas coming people.
- Thank you received: 1656
Also, do the Service Fuel Level check to verify that the fuel level in the carburetors is correct.
In theory it probably shouldn't leak when set to PRI, but in actuality it seems fairly common - mine leaks if I inadvertently leave it in PRI, but ON & RES are fine. My tank, petcock, & carburetors are clean and in very good condition. The petcock screen is good and there is a new in-line fuel filter & fuel line. The fuel level in each carburetor is set exactly at 3.0 mm below the carb body. In other words everything has been carefully checked, but PRI will leak a small amount sporadically.
- JR
- Thank you received: 449
martin_csr wrote: Assuming it's a vacuum petcock, set it to ON or RES, then check to see if it leaks.
+1
Prime only to fill the carb bowls after bike has been sitting
- jakedude
I have a hard time believing, from a liability standpoint, that Kawasaki would build a motorcycle that would dump the contents of it's gas tank when left on prime. Sure it would take time, but I was dripping about 1 drop per second. If I left that bike in the garage over night I would have a gallon of gas on my garage floor or more.
No it did not drip when not running with the petcock in ON or RES. That's not too surprising since the petcock is off when the engine is not running.
I have to believe that when running and vacuum opens the petcock that I would not be running too rich with carbs flooding.
I try an inline filter, purge the gas tank and let you know.
- jakedude
