Broken Petcock Intake
- 83KZ750LTD
19 Oct 2013 13:02 - 19 Oct 2013 13:06
Is it ok to use this petcock without the intake tower? I just pulled this from my gas tank because the petcock was leaking and the carbs were also over flowing in storage.
The gaskets and valve components were rotted and chewed up pretty bad so I'll either be getting a rebuild kit or a new petcock.
Attachment photo.JPG not found
1983 KZ750-F1 LTD - 8000 miles - 2/2015 - Head gasket time!
Last edit: 19 Oct 2013 13:06 by 83KZ750LTD.
- Motor Head
Re: Broken Petcock Intake
19 Oct 2013 13:37
That is both the Inlet Screen/ Filter, and has the 2 different height tubes for the ON and RES settings. You can get a replacement for it still I'm pretty sure depending on model.
19 Oct 2013 15:41
If the bolt hole spacing is 34mm, you might be able to use a petcock from a late model Police bike.
