category carbs
- 771000LTD
- 771000LTD
Re: category carbs
10 Oct 2013 08:56
Make sure the carb holder clamps are plenty loose and you may want to apply a thin film of Vaseline abound the carb holder openings where the carbs enter them. Ed
Re: category carbs
10 Oct 2013 11:53
For sure, make certain the clamps are floppy loose. I use silicone spray as a lubricant for rubber.
- baldy110
Re: category carbs
10 Oct 2013 11:56
If the manifolds are hard use a hair dryer and heat them up then spray some WD40 on the inside of the boots, they will slide right in.
- nickleo373
Re: category carbs
10 Oct 2013 12:07
Make sure your boots aren't folding over into themselves when you're pushing the carbs in.
1981 KZ550C LTD
"If you ain't first, you're last"
Re: category carbs
10 Oct 2013 21:57
Armor All performs well in this application.
