1000r
- 771000LTD
- 4TheKZ1000
- 771000LTD
- bluezbike
Re: 1000r
09 Oct 2013 22:12
:huh: What you trying to reinstall? And into what?
79 KZ 1000 LTD
- 771000LTD
- bluezbike
Re: 1000r
10 Oct 2013 20:50
Need some more info, pictures really help othewise it could be anything
79 KZ 1000 LTD
Re: 1000r
10 Oct 2013 22:06 - 10 Oct 2013 22:07
First, loosen the carb clamps -- very loose -- and apply Armor All to inside surfaces of carb holders and to outside surfaces of carb.
May alternatively use silicone lube or WD40.
Would avoid petroleum based products.
With the lubricating agent, carbs should push readily into position inside the holders.
Remember to later tighten the clamps.
Last edit: 10 Oct 2013 22:07 by Patton.
