Carb Cleaning - Disassembly
- PaulyWally
- Total Bike Newbie
04 Oct 2013 10:16 #608753
by PaulyWally
1976 KZ750 Twin
Carb Cleaning - Disassembly was created by PaulyWally
If I am going to do a carb dip, can someone tell me if either of these parts need to be removed from the carb? I pulled the big one (needle jet?) out of one. There was a rubber washer that would probably need replacing. But because it was so difficult to remove, I wasn't sure that I was supposed to.
Attachment 2013-10-0407.22.15.jpg not found
1976 KZ750 Twin
- sbc1320
- Thank you received: 38
04 Oct 2013 12:25 #608769
by sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic Carb Cleaning - Disassembly
Leave them, but wash them out good with carb cleaner and blow all orifices with compressed air. Make sure all the small holes are clean. You can use a small wire or cutting torch tip cleaner(use the tip that is closest size to hole or smaller, but not bigger) being careful not to open up the holes to a bigger size. Good luck.
- nickleo373
- Thank you received: 33
04 Oct 2013 20:42 #608805
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic Carb Cleaning - Disassembly
The main jet that you took out should be the only one with a rubber o ring on it
1981 KZ550C LTD
- Motor Head
- Thank you received: 391
04 Oct 2013 22:36 #608810
by Motor Head
Replied by Motor Head on topic Carb Cleaning - Disassembly
The smaller tube in your photo is the starter jet. As stated, don't remove it, its pressed in and could easily be damaged by trying to remove it.
