kz440 float bowl o-ring
  • stmats
  • stmats's Avatar Topic Author
02 Oct 2013 23:02
#608613
I've been trying to get this old bike running. In the process of cleaning out the carbs, I noticed that the float bowl o-rings were hard, dry and not likely to seal well again. After searching all over town, I finally broke down and ordered a set from fleabay. I got the new o-rings today, but they're about 1mm too small and won't stay in the groove long enough for me to re-attach the float bowl. Can I expand the rings by warming them up or should I just send them back and order from the dealer?
I like old things. I like fast things. I like old fast things.
Re: kz440 float bowl o-ring
02 Oct 2013 23:17
#608617
I would return them and buy the correct parts. You really don't want to end up with gasoline running onto a hot engine. The carb bowl o-rings are still an "Active" Kawasaki part, so any local or online dealer can get them for you. Partzilla lists them at $9.99 each.
find.partzilla.com/?r=t&q=16019-024&x=11&y=6
You should add you bike's year and model to your signature line; it makes it MUCH easier for us to help you.
Attachment 00001_2013-10-02-2.jpg not found
  • martin_csr
  • martin_csr's Avatar
03 Oct 2013 07:49
#608627
Z1Enterprises.com has K&L float bowl o-rings & K&L carb kits. K&L parts are made in Japan & oem quality - imho.
  • undiablo
  • undiablo's Avatar
06 Oct 2013 19:04
#608993
If you want to save money, there is no need to buy super expensive OEM Kawasaki o`rings.
See my post below, it is for KEIHIN CV34 carbs.
www.kzrider.com/forum/3-carburetor/57641...at-bowl-oring-gasket
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
