- Thank you received: 6
jet question
- crusierlover
02 Oct 2013 11:39 #608563
by crusierlover
Proud owner of 1982 650csr again soon. keeping it this time
jet question was created by crusierlover
I have an 89 kz 1015 with vance and hines 4 into 1 when i bought it.It runs like crap.it has mismatched pod filters for 1, but also has lot of bluing on headers, meaning lean.What are stock jets and what size should i go up to?
- hill
- 78 kz1000
- Thank you received: 1
05 Oct 2013 01:02 #608833
by hill
Replied by hill on topic jet question
Not sure what size stock are.You should get a manual,get all the same filters.Buy filters that use oil on them,like k&n.Remove the carbs,clean float bowls,& make sure all the ports are clean by blowing air through them.Pull your main jets,& pilot jets to make sure the little holes in them are clean.If its running lean it usually is popping.If its rich,its chugging.Smell the exhaust.Also,just because the plugs don't look bad,doesn't mean there not fouled.Spend 24$ for a couple sets of plugs before you start tuning.
The following user(s) said Thank You: crusierlover
- crusierlover
05 Oct 2013 03:25 #608837
by crusierlover
Replied by crusierlover on topic jet question
I have a manual.It pops,doesnt chug.I bought it to make into a cafe racer, but a friend of mine and I have another frame we are modifying.Once the motor is pulled we will go through it.new kan ns cost over $200 now.
- Thank you received: 2098
05 Oct 2013 09:27 - 05 Oct 2013 09:27 #608844
by Patton
Replied by Patton on topic jet question
Perhaps one of the less expensive EMCO pod sizes will fit.
www.z1enterprises.com/ShopByCategory.asp...arts&category=010444
Some pod designs are prone to obstruct holes at carb intake, and therefore require careful attention -- and possible trimming -- when installing them.
Can usually find stock jet sizes on kawasaki.com.
Pods plus 4>1 may perform better with one size or perhaps two sizes larger main jet.
Sometimes the stock pilot jet is okay, or perhaps one size larger.
Spark plug readings provide good evidence as to optimal jet sizes.
Last edit: 05 Oct 2013 09:27 by Patton.
