dynojet kit problems... help !!!
- baruch77
29 Sep 2013 16:07 #608250
by baruch77
80 kawa 750ltd h1 bobber project.
dynojet kit problems... help !!! was created by baruch77
Hi every one, I need your help please to finish my project, I have a 1980 Kawasaki kz750h ltd, I turn in to a bobber-chooper, I have to rejet the carbs for a open pipes and pod filters in the cabs, I brought a dynojet kit stage 1-3, for my bike, but I have a problem the size on the main jet in the kit its smaller than the main jet in my bike, the cabs in my bike are a keihin, and the kit number and specs on the kit are for 80-83 Kawasaki kz750B/E kz750H LTD kz750N spectre... I don't know if some one are using this kit before and can help, me or give me an idea if Im doing some thing wrong, my carbs have only 3 jets inside the float bowl... any of those jet dont have it the same size than the jet kit jet. thanks
- Motor Head
- Thank you received: 391
29 Sep 2013 16:11 #608252
by Motor Head
Replied by Motor Head on topic dynojet kit problems... help !!!
The numbering is completely different from Keihin, Mikuni, and Dyno Jet. So don't go by the # on the Jet.
- baruch77
01 Oct 2013 01:58 #608435
by baruch77
Replied by baruch77 on topic dynojet kit problems... help !!!
Thanks for your answer, but I'm confuse... The dynojet kit have 4 different numbers of main jets, but any fit on my carbs... SOMEONE KNOWS WHAT CAN I DO TO REJET MY CABS.. THANKS
- Jrbrownie00
- Thank you received: 9
02 Oct 2013 09:52 #608546
by Jrbrownie00
82' kz750 ltd.
Replied by Jrbrownie00 on topic dynojet kit problems... help !!!
It's listed in the instructions. Your main jet should be a 126, the kit includes 4 of each (116, 122, 130 and 136 or should) Stage 1 or a 4-1 pipe and factory air cleaner you are to use the 130. Stage 3 or pods and a 4-1 pipe you are supposed to use the 136.
Here's a copy of the instructions included in the kit. www.dynojet.com/pdf/2102.pdf
Cheers!
Cheers!
82' kz750 ltd.
- bluezbike
- Thank you received: 104
02 Oct 2013 13:31 #608575
by bluezbike
79 KZ 1000 LTD
Replied by bluezbike on topic dynojet kit problems... help !!!
Where did you buy the Dynojet kit? Did you specify your bike when you got the kit? It could be the wrong one
79 KZ 1000 LTD
