Is It true ??
25 Sep 2013 15:15 #607732 by pete greek1
Is It true ?? was created by pete greek1
Is It true, that if you fill up your tank,& run it thru your carbs, (Racing Fuel), that you don't have to worry about using a stabilizer, or the fuel going bad, when storing over the winter ??...Pete
  • slayer61
  • KZR FLAG RELAY CARRIER #62
25 Sep 2013 16:50 #607747 by slayer61
Replied by slayer61 on topic Is It true ??
My experience with race fuel (VP110 leaded) is yes. It is much more stable than pump swill. It will not spoil for a year or more.
25 Sep 2013 16:55 #607750 by 531blackbanshee
Replied by 531blackbanshee on topic Is It true ??
i use phillips 66 tt 111 racing fuel in my banshee.
and it seems to stay good for a long time,like over a year.
The following user(s) said Thank You: pete greek1
25 Sep 2013 17:03 #607752 by 650ed
Replied by 650ed on topic Is It true ??
I'm not a believer in letting a bike sit over the Winter without being run periodically, even if with fuel stabilizer or fuel that is inherently stable. If you do plan to do that you probably should "fog" your bike's cylinders with "motor fogging oil" the same way boat motors are done when being stored. I run my engine at least once every 2 weeks over the Winter for about 15 minutes. Doing this ensures no fuel sits in the carbs too long, but just as important (to me) it ensures oil remains on the cylinder walls, cams, etc. and it keeps the battery fresh. I let it warm up thoroughly to evaporate any condensation that may form in the pipes. I skipped this routine once about 20 years ago and was rewarded by having to remove and clean the carbs. That was enough to convince me not to let it sit. Ed
  • slayer61
25 Sep 2013 17:28 #607756 by slayer61
slayer61 wrote: My experience with race fuel (VP110 leaded) is yes. It is much more stable than pump swill. It will not spoil for a year or more.
Let me clarify...
I have a race bike that consumes VP110. At the end of the season, I put the bike in proper storage,(drain oil, gas and top-end oiled) but the fuel in the can is good to go the following season. My .02 Paul
25 Sep 2013 17:37 #607759 by pete greek1
Replied by pete greek1 on topic Is It true ??
Thanks Blackbashee, & Slayer, & I agree with 650ed, I like to start & let it run for about 15 mins. at least once a month, I also move it about a foot,or so, either forward or backword, so the tires are not sitting on one spot all winter, I also use a smart charger, that turns off automatically when the battery is fully charged, & when the battery gets a little low it will turn itself back on till fully charged .. as a regular trickle charger will stay on all the time, & ends up frying the battery a lot sooner ...Pete
25 Sep 2013 17:42 #607760 by pete greek1
P.S. how do you post thanks, to individuals on their time line ??
  • slayer61
25 Sep 2013 17:57 #607761 by slayer61
pete greek1 wrote: P.S. how do you post thanks, to individuals on their time line ??
the red box in the bottom of the post you wish to say "thank you" for?
  • slayer61
25 Sep 2013 17:59 - 25 Sep 2013 18:00 #607762 by slayer61
the red box in the bottom of the post you wish to say "thank you" for ?
Dammit. The red box in the bottom of the post for which you wish to say "thank you"? My English teacher would be appalled!
Last edit: 25 Sep 2013 18:00 by slayer61.
25 Sep 2013 18:11 #607764 by pete greek1
Slayer, I wouldn't think it would be a good idea to leave the oilpan, drained of oil all winter, don't think it would be good for the bottom end, or the oil pump, ...but I'm not a mechanic :(
25 Sep 2013 18:29 #607765 by pete greek1
I just have to start wearing my glasses more often, Thanks Slayer !!!!
  • slayer61
25 Sep 2013 18:46 #607767 by slayer61
pete greek1 wrote: Slayer, I wouldn't think it would be a good idea to leave the oilpan, drained of oil all winter, don't think it would be good for the bottom end, or the oil pump, ...but I'm not a mechanic :(
Pete,
It's a "dry sump" motor and the oil pump gets primed prior to start-up ;) Paul
