Tips for First start up in 25 years
- b0ssdawg
24 Sep 2013 16:36 - 24 Sep 2013 22:44 #607610
by b0ssdawg
Rusty old 1976 kz900
Tips for First start up in 25 years was created by b0ssdawg
ok so i finally got a spark (i hope its strong enough), my carbs are rebuilt (dont know if the adjustments are right) and i just realized my Carburetor Holders had holes in it, so i ordered some new ones. Any other tips for first start up would be greatly appreciated.
Edit: sorry its a 1976 kz900
Last edit: 24 Sep 2013 22:44 by b0ssdawg.
- baldy110
- Thank you received: 512
24 Sep 2013 17:15 #607618
by baldy110
Replied by baldy110 on topic Tips for First start up in 25 years
If you just go the bike I would od the following.
1. Change oil and filter.
2. Change spark plugs.
3. Drain gas from tank and if needed clean out tank and re-fill with good gas.
4. Disassemble and clean the carburetors REALLY well.
5. Check, clean and adjust points if applicable.
6. Check, clean, lube timing advancer.
7. Replace air filter.
8. Check and adjust valve clearances if needed.
9. Check and adjust timing chain tensioner.
10. Replace tires and tubes if applicable.
11. Replace drive chain.
12. Clean and lube every cable.
13. Check and if needed replace brake pads / shoes.
- Thank you received: 2098
24 Sep 2013 17:30 #607624
by Patton
Replied by Patton on topic Tips for First start up in 25 years
Including information about bike year and model is helpful to viewers and usually elicits better responses.
It's easy to put the information in your signature where it shows in all posted messages, past and future.
And may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Attachment addsig.jpg not found
- b0ssdawg
30 Sep 2013 18:25 #608384
by b0ssdawg
Replied by b0ssdawg on topic Tips for First start up in 25 years
so i have started to turn in over and im getting some puffs, im not sure if my spark is strong enough (im going to sand down my points a little bit more), and do the breather lines (the top outlet on the carburetor) have to go anywhere, i cant remember where they were when i pulled the carb, also any advice for where to put the mixture screws? and choke on im guessing? no extra gas with throttle?
Sorry im a noob
Sorry im a noob
- b0ssdawg
30 Sep 2013 21:25 - 30 Sep 2013 21:26 #608403
by b0ssdawg
it started!!!!!!!
Edit: doesnt represent how happy i am!!!!!!! :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
Last edit: 30 Sep 2013 21:26 by b0ssdawg.
01 Oct 2013 05:23 #608441
by Patton
The two hoses from the carb vent nipples exit to open air.
The original air box has molded-in clips on top of the air box to retain the hoses.
The following user(s) said Thank You: b0ssdawg
