kz900 carb upgrade
  • etbike3135
  • etbike3135's Avatar
Re: kz900 carb upgrade
20 Sep 2013 07:42
#607138
Why not get a set of stock 28's? For about $200 you can get a nice set and in my opinion way better then the 26's.
1973 Kawasaki Z1
18 years in dragbikes
  • Motor Head
  • Motor Head's Avatar
20 Sep 2013 09:50
#607146
etbike3135 wrote: Why not get a set of stock 28's? For about $200 you can get a nice set and in my opinion way better then the 26's.
Biggest Bang for the $$$.
If you go much bigger, you should really make head and cam mods, with a header to get the gains of bigger carbs.
  • dshelly
  • dshelly's Avatar
20 Sep 2013 10:33 - 20 Sep 2013 10:35
#607151
Cynjut wrote: There's a company that will do a 'pseudo' 29mm bore on existing 26mm carbs. I don't have the details, but they are in the desert southwest someplace.
I've bored several sets of them . There is a trick to getting them to work. It's not that hard if you have the right equipment. I plan on doing a couple sets pretty soon. Also did a write up on here a while back.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
Last edit: 20 Sep 2013 10:35 by dshelly.
