kz900 carb upgrade
- stunter956
kz900 carb upgrade
19 Sep 2013 00:24
Ok i want to upgrade from my stock 26mm mikunis to some 29mm smoothbores i was told the cb750 has them and fit on the kz but i
Dont know wat year they come from also been told that the kz650 has them aswell. Can someone chime in some info on this.
Attachment 20130912_180411.jpg not found
1976 kz900 "mean green"
Re: kz900 carb upgrade
19 Sep 2013 00:30 - 19 Sep 2013 00:31
Per Z1E:
We have included the Honda CB750 settings as a reference. You will notice the similarity of setup - so.... if you can find a set of 29mm carbs off a CB750, they should work on a Z1.
www.z1enterprises.com/Z1CarbGuide.aspx
Last edit: 19 Sep 2013 00:31 by Patton.
19 Sep 2013 00:32
The KZ650 never came with them. Ed
- stunter956
19 Sep 2013 00:37
The chart patton provided does show a kz650 with 29mm carbs.
19 Sep 2013 00:48 - 19 Sep 2013 00:48stunter956 wrote: The chart patton provided does show a kz650 with 29mm carbs.
That chart is simply showing what the jetting would be if the carb is used on that model bike. It was not intended to imply that those are the carbs that came as original equipment on those bikes. Believe me, no KZ650 ever came with 29mm smooth bore carbs as original equipment. Ed
Last edit: 19 Sep 2013 00:48 by 650ed.
- stunter956
19 Sep 2013 01:49
Ahh i see my bad.. So incase i find some carbs would they fit right in with my stock boots?
- testarossa
19 Sep 2013 07:53 - 19 Sep 2013 07:54stunter956 wrote: Ahh i see my bad.. So incase i find some carbs would they fit right in with my stock boots?
Similarly to the KZ650, no CB750 ever came with VM29 smoothbores from the factory. In fact, the smoothbores were never a factory installed carb for any bike, but were a common performance upgrade available through Kawasaki, Honda, and Suzuki dealers.
To answer your question, yes the 29mm smoothbores are a direct fit in your stock boots for VM26 carbs.
Please note that if you locate some smoothbores which came from a Suzuki, to check the slide cutaway size. The Suzuki carbs used larger 2mm cutaways which make tuning for a KZ difficult. Replacement slides with 1.5mm cutaways are available, but a set of 4 will set you back about $240 plus tax and shipping. Also stripped jet blocks are a common problem. Also repairable, but again you are looking at about $160 plus tax and shipping for a set of new jet blocks.
The 29mm smoothbores are excellent carbs when dialed in, but if the seller knows what he has, they will likely sell for $500 to $700. If you lay out that kind of cash and get a set that needs slides or jet blocks it will add up fast.
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
2004 ZX-10R
Angola, IN
Last edit: 19 Sep 2013 07:54 by testarossa.
- stunter956
19 Sep 2013 10:08
Yea i knew wat i was gettin my self into wen it came to the price haha was making up my mind wether to tune my mercedes computer or do this to my bike. Guess im sticking to carb upgrade instead. Thanks for the info bro i talked to a buddy that is helping me with the search and hopefully he hunts a set down
- Cynjut
19 Sep 2013 11:40
There's a company that will do a 'pseudo' 29mm bore on existing 26mm carbs. I don't have the details, but they are in the desert southwest someplace.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
- fitscott
19 Sep 2013 12:16
I think you might be thinking of WIRED GEORGE in San Antonio
- Cynjut
19 Sep 2013 13:21
Sounds right. He's been popping up in one of the other forums I read. I've never had him do the work, but the price sounded right and if it works, could save about $1500 over buying a set of actual smooth-bores.
1977 KZ-1000 A1
- dbc92s10
20 Sep 2013 07:20
Let me tell you from my own experience you are way better off to buy new carbs I would just get whole of schnitz racing they have carbs way cheaper than anyone else . For around 700 you can have a new set of carbs shipped to you, by the time you buy a used set and buy parts, jets etc.. you will be money ahead to buy new
81 ltd1000
1135 mtc 10.5/1
cavanaugh racing head
38.6/32 p&p
APE k410 cams
APE hardware and tensioner
84 gpz1100 trans
kerker w comp baffle
rs36 carbs
fast by gast race crank
1135 mtc 10.5/1
38.6/32 p&p
APE k410 cams
84 gpz1100 trans
rs36 carbs
