78 KZ 650 B2 Vacuum Petcock Problems
  • ZR_Demko
  • ZR_Demko's Avatar Topic Author
16 Sep 2013 15:58
#606689
I've been having trouble with fuel getting into the vacuum line on the petcock due to a torn/worn diaphragm. I ordered the K&L rebuild kit, but the diaphragm in the kit ended up being completely different and I wasn't able to use it. I managed to find a quick fix, but now there's fuel seeping into the vac line again.
I'm looking at a couple replacement petcocks on ebay, but I'm afraid I'll keep having the same problem with the diaphragms disintegrating. Does anyone have any suggestions on what kind I can look into?
Thanks!
Zach D.
Zach D.
78 KZ650
  • CoolerKing
  • CoolerKing's Avatar
Re: 78 KZ 650 B2 Vacuum Petcock Problems
16 Sep 2013 16:05
#606690
Check out these threads over on kz650.info
forums.kz650.info/index.php?topic=1221.0
forums.kz650.info/index.php?topic=8222.0
I'm running the Suzuki one, it works great but the fuel outlet comes out the wrong side so you need to run a longer fuel line.
1978 KZ650-C2
1976 KZ400D-3 (sold)
  • Cynjut
  • Cynjut's Avatar
16 Sep 2013 16:17
#606691
Go manual.
I replaced the one on my 82 CSR with a manual one and never looked back.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
16 Sep 2013 17:06
#606694
I suggest you just rebuild it using the correct parts from Kawasaki rather than relying on an aftermarket kit. The diaphragm, gaskets, o-rings, and spring are all still "Active" parts so any online or local dealer can order them for you. The total cost at Partzilla.com is $20.41 for all 7 parts. Ed
Attachment 00001_2013-09-16-2.jpg not found
The following user(s) said Thank You: ZR_Demko
  • ZR_Demko
18 Sep 2013 00:31
#606881
Thanks for the help everyone.
I decided to order the parts online and go from there - I had to remind myself that I want to keep everything as stock as possible ha. Thank you Ed.
Zach D.
78 KZ650
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
24 Sep 2013 16:54
#607614
Having went the Z1/suzuki petcock route, AND cleaned my tank vent (Thanx again, 650Ed!!!) I thought I would weigh in on this one....Unless I run on "prime", I am still experiencing fuel starvation issues at 50 mph plus. May try to rebuld original. Might go for one of those snazzy non-vacuum "made in the midwest" versions...I DO like the sound of that....might just keep remembering to switch it when I get on/off...GOTTA get SOME reliable source of fuel to her..they bog at the wrong time, and it can make for a bad day! I suspect that it is probably not the petcock's fault...I am leaning toward a low vacuum signal due to low(ish) compression, not fully opening the diaphragm.Thoughts, experts?
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • nickleo373
  • nickleo373's Avatar
24 Sep 2013 17:12
#607617
Do you have a fuel filter that could be clogged up? It took me a month to figure out my bike wasn't getting enough fuel because the filter was bad :whistle:
1981 KZ550C LTD
"If you ain't first, you're last"
  • Grumpy Ole Artist
24 Sep 2013 17:16
#607619
Thanx, but brand new, (polaris type) in-line.
1978 KZ650 B2
