29mm smoothbores
- CW1
11 Sep 2013 15:31 #606026
by CW1
29mm smoothbores was created by CW1
Hi trying to sync carbs and I cant find instructions anywhere I have a clymer that has them for original carbs they seem to be different I have a kz1000 1979 ltd b3 if someone has this info or know where to get it that would be cool Thanks
- Thank you received: 2098
11 Sep 2013 16:34 - 11 Sep 2013 16:35 #606040
by Patton
May employ same sync method as with other Mikuni manual slide carbs.
Sudco suggests bench sync only -- without vacuum sync -- due to vacuum leak created with carb top covers removed.
But, of course, lots of us ignore that advice, and vac sinc'em anyhow. :woohoo:
Easy enough to verify sync condition by simply comparing the vacuum readings with sync tubes attached to fully assembled carbs while engine is at idle rpm.
Replied by Patton on topic 29mm smoothbores
CW1 wrote: Hi trying to sync carbs and I cant find instructions anywhere I have a clymer that has them for original carbs they seem to be different I have a kz1000 1979 ltd b3 if someone has this info or know where to get it that would be cool Thanks
Last edit: 11 Sep 2013 16:35 by Patton.
- kzz1king
- Thank you received: 52
11 Sep 2013 23:30 #606112
by kzz1king
Home built KZ1000 turbo setup
Replied by kzz1king on topic 29mm smoothbores
I just bench sych and ride.
Wayne
Wayne
