kz400 single carb help
- beamer
11 Sep 2013 14:07
i know this topic has been beat to death...but here it goes.
what carb is the best to use on my 76 kz 400 with a 11th hour 2 into 1 intake.
currently i have a keihin pj34 and don't want to spend too much time chasing something i will never get dialed in.
it seems like all the threads i read nobody has gotten that perfect carb setup.
any help would be great.
- loudhvx
Re: kz400 single carb help
11 Sep 2013 15:55
Have you checked the KZtwins forum? There's a bunch of info about single carb conversions there.
www.armbell.com/kz400/index.php?sid=c35c...fcc2365&mforum=kz400
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
11 Sep 2013 19:46
A while back, someone on KZR used a carburetor from a late model Kawasaki ATV, a KVF400 or KFX or something like that in the 2004-06 year range. I couldn't find the topic - it was 440 bobber or 440 custom bobber. He made a manifold from copper pipe & fittings and the single pod filter was angled towards the side.
- barreto
11 Sep 2013 20:19
I got damn near perfect with the setup I did on my KZ440.
Here's the thread for it- www.kzrider.com/forum/3-carburetor/58752...ngle-carb-conversion
If you bought a new carb, I'd go with a VM30 or VM32 and step the main jet down to a 150 or so. The #25 pilot jet should be about right too.
beamer wrote: i know this topic has been beat to death...but here it goes.
- beamer
12 Sep 2013 15:47
did you specify the 30 or 32 because the 34 may be a bit big for the kz400.
- barreto
12 Sep 2013 15:55
yeah just based on my experience with the 440. I would think a 32 would be perfect on the 400. you could probably get the 34 to work with a #25 pilot and #140 or #150 main. I've never worked with a Keihin slide carb but I would think the jet sizes are similar? someone else might have to chime in on that one.
- beamer
12 Sep 2013 16:13
thanks for the info...I will keep you posted on what I do.
- flint
13 Sep 2013 18:50
11thhourindustries.com/store/#!/~/catego...offset=0&sort=normal
This guy builds them. I would've but, I'm selling the one I'm putting this manifold on. Anyways he goes with a keihen pw 35mm?
one piece at a time
1980 kz440 ltd a-1 (bobber thing)
1980 kz440 d-1 (stripped down scooter)
