FUEL QUESTION
- lhemrick
07 Sep 2013 19:57 - 07 Sep 2013 19:59 #605419
by lhemrick
FUEL QUESTION was created by lhemrick
I have an 81 KZ550. Do I need to concern myself with Ethanol in my fuel? I usually purchase 100% gasoline but the only station in my area that has it has let me down. I filled up the other day and suddenly couldn't get the bike over 60. It just wouldn't go any faster. I drained it went and got some other fuel (with Ethanol) and it runs fine now.
Thanks!
Thanks!
Last edit: 07 Sep 2013 19:59 by lhemrick. Reason: Forgot to subscribe to the topic
- 4TheKZ1000
- Visitor
07 Sep 2013 20:16 - 07 Sep 2013 20:18 #605422
by 4TheKZ1000
Replied by 4TheKZ1000 on topic FUEL QUESTION
If its 10 or 15% you are ok....It might become a concern over 15%.
We are 10% in Ohio and I don't have a problem.
They are required to post the percentage of ethanol on the pump.
Last edit: 07 Sep 2013 20:18 by 4TheKZ1000.
- Nebr_Rex
- Thank you received: 300
07 Sep 2013 20:42 #605426
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic FUEL QUESTION
Here in Nebraska we have had e-10 since the "70s. Used to be called Gasahol.
Gasoline has changed over the years. I believe the octane is right but it burns
faster. Also it was ok to let a vehicle set for a period of time. Now the gas breaks
down in no time, diesel fuel is even worse.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Motor Head
- Thank you received: 391
07 Sep 2013 20:45 #605427
by Motor Head
Replied by Motor Head on topic FUEL QUESTION
One of the biggest problems is that it doesn't store well at all. Don't leave it sit in your bike all winter, if you have that where you live. It can eat certain parts that were never designed to run alcohol. It turns back into a sticky brown mess, Corn Sugar. It can make an engine run leaner, do to the higher specific gravity of the fuel, so on a two cycle a re-jet is needed. With a Feed Back closed loop fuel injection, the 02 sensor sees the lean condition and compensates with a longer injector pulse width, lowering fuel economy.
Government Mandated Crap. Look what its done to the price of a decent corn feed steak!
