- Thank you received: 9
KZ 200 Can't drop idle - Keihin PW26
- Spectre1982
06 Sep 2013 17:04 #605245
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
KZ 200 Can't drop idle - Keihin PW26 was created by Spectre1982
I'm working on my KZ200. Every time I start it up, it wants to race away up to 5K+ rpm. It seems like no amount of adjustment with the air screw or idle screw makes a difference. The compression is at 150 psi and the timing is good. Valves are in spec. Just set the float level on the carbs. Throttle cable is set right. I have a pod air filter. According to my manual the pilot is supposed to be a 38 and the main is a 105. I noticed my carb has a 42 pilot and 110 main. Is the larger pilot causing my problems? Any thoughts?
Thanks
Thanks
1978 Kawasaki KZ200
- koolaid_kid
- Thank you received: 99
06 Sep 2013 17:34 #605246
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic KZ 200 Can't drop idle - Keihin PW26
Check for intake leaks.
1983 GPz 750
- Spectre1982
06 Sep 2013 18:47 #605254
by Spectre1982
1978 Kawasaki KZ200
Replied by Spectre1982 on topic KZ 200 Can't drop idle - Keihin PW26
The intake boot looks good. It's pliable with no cracks.
1978 Kawasaki KZ200
- Spectre1982
06 Sep 2013 19:03 #605256
by Spectre1982
1978 Kawasaki KZ200
I just got it. I had to set the idle screw all the way out where it's about to fall out. I didn't think i needed to adjust it that far out. I feel dumb. Starts on first kick and idles like a champ. Thanks.
1978 Kawasaki KZ200
