1976 KZ900LTD
- rawnascar
05 Sep 2013 12:55 #605009
by rawnascar
1976 KZ900LTD was created by rawnascar
I have had this bike for about a month. I have set timing cleaned carbs. Are these things cold blooded. Have to use choke to start when cold. After it warms up it starts good. Also when running if I put it on kick stand it will stall
- koolaid_kid
- Thank you received: 99
05 Sep 2013 14:45 #605034
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic 1976 KZ900LTD
It is a carbureted engine, not fuel injection. You must richen the mixture manually when the engine is cold. Your fuel injected bikes and cars do this automatically for you.
If the engine dies when you put it on the sidestand, that is normal, you are changing the fuel levels in the fuel bowls. If the engine dies when you put it on the centerstand, no, that is not normal.
1983 GPz 750
- sbc1320
- Thank you received: 38
05 Sep 2013 15:27 #605041
by sbc1320
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
Replied by sbc1320 on topic 1976 KZ900LTD
Yes on what he said^^^^
Probably sloshing fuel when putting it on the centerstand and causing it too momentarily flood out.
