No Choke On 79 KZ 650
- cleosdad2001
01 Sep 2013 23:54 #604372
by cleosdad2001
No Choke On 79 KZ 650 was created by cleosdad2001
I made the mistake of not firing up the bike this past winter for a couple of months. When I did fire it up, it won't stay at high RPMs with the choke on. It will initially idel high then immeadiately come down and sputter out. I can eventually warm up the bike without choke by working the throttle. Any ideas out there, help!
- Thank you received: 2829
02 Sep 2013 00:22 #604375
by 650ed
Replied by 650ed on topic No Choke On 79 KZ 650
If the bike sat that long the carbs are probably clogged up. That happened to me once - never again! You probably need to thoroughly clean the carbs. Ed
- mtkawboy
- Thank you received: 16
05 Sep 2013 18:24 #605083
by mtkawboy
Replied by mtkawboy on topic No Choke On 79 KZ 650
Drain the carbs in winter, remove fuel line from petcock and plug, put a piece of plugged hose on the petcock, fill gas tank completely and put Stabil it too. Toss the old gas in the spring, mean while as mentioned carbs will need to be cleaned in pilot circuits. That's worked for me on my GPZ750 for 31 years
