- Thank you received: 3
Replacing stock exhaust with V&H 4 into 1
- mountain
- go with the flow
29 Aug 2013 22:37 #603828
by mountain
1977 KZ 650 B1, I own two of them. Working on one custom rebuild, one daily rider. Used to have a third. Two 1978 KZ 650 C2 models, sold both. KZ owner since 1987.
Replacing stock exhaust with V&H 4 into 1 was created by mountain
I am simply replacing my stock exhaust with a Vance and Hines new 4 into 1 chrome Exhaust from Z1 Enterprises. I like the stock air box, that is what i have. What is the adjustment to the carburetor that needs to be done? I can remove jets and replace/swap easily if i can get the right ones, also can move main needle attachment up or down if necessary. Carbs work great with 4 into 2 but exhaust is shot, broken, rusted and fell apart when removed. Shoot me to the right archive if there is one please! Thanks
- Beaner242
- Thank you received: 16
29 Aug 2013 23:21 #603837
by Beaner242
1982 KZ1000K LTD Chopper
Replied by Beaner242 on topic Replacing stock exhaust with V&H 4 into 1
Get you the Dyno jet kit. Comes with everything you need and instruction for which ever mods you have.
- Motor Head
- Thank you received: 391
29 Aug 2013 23:31 #603846
by Motor Head
Replied by Motor Head on topic Replacing stock exhaust with V&H 4 into 1
Being in the 6K' of Denver, I would say you should be ok as long as you stay above 3K'. Try it and check your plugs. I had my bike in Colorado Springs, with the V&H with stock jets.
- mountain
- go with the flow
30 Aug 2013 10:52 #603907
by mountain
Replied by mountain on topic Replacing stock exhaust with V&H 4 into 1
Oh ya, duh. I have a '77 KZ650 B1 model. I like the idea that stock may work as long as i don't lean it out by going to low. In fact, i like to do the high mountain passes and some are over 12,000feet. Ill check the plugs so i don't burn a hole in my pistons
Thanks!
Thanks!
