KZ550 misfires
  • nickleo373
  • nickleo373's Avatar Topic Author
KZ550 misfires
26 Aug 2013 14:26
#603150
Hey everyone. Last week I adjusted the float heights on my 81 KZ550. The previous float heights were causing gas to overflow into the cylinders and air box. I adjusted it to 18.5mms and put the carbs back on the bike. Now it idles rough and dies when I give it throttle without the choke on. When it idles the rpms are really low and it misfires. Does anyone know what's making it do this?
Thanks
1981 KZ550C LTD
"If you ain't first, you're last"
Re: KZ550 misfires
26 Aug 2013 23:31
#603249
nickleo373 wrote: Hey everyone. Last week I adjusted the float heights on my 81 KZ550. The previous float heights were causing gas to overflow into the cylinders and air box. I adjusted it to 18.5mms and put the carbs back on the bike. Now it idles rough and dies when I give it throttle without the choke on. When it idles the rpms are really low and it misfires. Does anyone know what's making it do this?
Thanks
Would suspect leaking float valves were causing the overflows, and that the overflows were largely unrelated to the float heights.
Would correct the float valves, and re-adjust the float heights, using the clear tube test method.
Good Fortune! :)
  • nickleo373
Re: KZ550 misfires
26 Aug 2013 23:33
#603250
Thanks for the reply. I noticed when putting the floats back on the carbs that the piece with the spring that opens and closes the valve will slide down when the carbs are placed on the bike. It doesn't fall out of place but the whole piece drops down with the floats. Is this normal or are they broken?
1981 KZ550C LTD
  • The_Proletariat
  • The_Proletariat's Avatar
  • "Cocaine is a hell of a drug"
Re: KZ550 misfires
27 Aug 2013 21:56 - 27 Aug 2013 22:00
#603411
Yes, that is normal. If you remove the float they should fall out. If they don't they may be stuck in the seat causing your overflow problem.
They open and close depending on the height of the float. Make sure the seat and tip of the valve are not worn.
1982 Kawasaki KZ550 LTD
Last edit: 27 Aug 2013 22:00 by The_Proletariat.
  • nickleo373
Re: KZ550 misfires
27 Aug 2013 22:10
#603418
Thanks. They were stuck in before I cleaned the carbs so thats how I thought they were supposed to be. It's all freed up now so it should be alright
1981 KZ550C LTD
  • Jedsdead
  • Jedsdead's Avatar
Re: KZ550 misfires
28 Aug 2013 14:15
#603527
I've got an 83 kz 550H, which I am going to readjust my float heights on. My manual indicates a fuel level of 6mm +/-1mm below the top of the float bowl.
Because these float needles do not have a clip on them that holds them to the actual floats (like most others I've seen) the needle just falls in and out of place. So what you are seeing is normal.
1983 KZ550H GPz
The following user(s) said Thank You: nickleo373
  • nickleo373
Re: KZ550 misfires
29 Aug 2013 19:53
#603789
I just made sure the valves aren't clogged or stuck and I set the floats using the clear tube. I put the bike back together and now it will idle only with the fast idle screw turned all the way out. It'll idle like crap for a few seconds and then dies. Does anyone know what this could be?
1981 KZ550C LTD
  • Motor Head
  • Motor Head's Avatar
Re: KZ550 misfires
29 Aug 2013 22:00
#603817
It sounds like you could either have set the fuel level incorrectly, or have a vacuum leak, or still plugged up slow/ pilot circuits.
  • nickleo373
Re: KZ550 misfires
31 Aug 2013 17:25
#604169
Turns out it was a dying battery. I charged it and the bike will turn on and idle like normal. I believe my #3 cylinder isn't firing because after revving the bike the #3 header is warm while the others are too hot to touch. The first thing I want to check is the fuel level but I can't do the clear tube test because the float bowl drain screw is seized up. Ive been spraying liquid wrench and pb blaster on it for months and it won't come out. Is there another way to check the fuel level?
1981 KZ550C LTD
  • loudhvx
  • loudhvx's Avatar
Re: KZ550 misfires
31 Aug 2013 17:41
#604174
In my signature, there is a link to my TK22 site. In the maintenance section, there is a description on how to roughly set the fuel level while dry, and carbs off of the bike.
If the fuel needle has a ring aroud the tip with a noticeable ridge, the needle and seat should be replaced.
  • nickleo373
Re: KZ550 misfires
31 Aug 2013 17:52
#604177
Thanks Loudhvx. That was helpful. How do you take the float bowls off with the carbs on the bike to make adjustments after I reset them? Mine have the JIS screws that came with the bike and I can't find a screwdriver anywhere that will fit between the crankcase and the carbs
1981 KZ550C LTD
Re: KZ550 misfires
31 Aug 2013 19:45
#604187
nickleo373 wrote: Thanks Loudhvx. That was helpful. How do you take the float bowls off with the carbs on the bike to make adjustments after I reset them? Mine have the JIS screws that came with the bike and I can't find a screwdriver anywhere that will fit between the crankcase and the carbs
Good question! Here's what I use. A little modified to JIS screwdriver bit in a socket with a 1/4" ratchet. A mirror helps so you can see the screws as you seat the bit. Ed
Attachment carbscrewdriver.jpg not found
