1983 kz750f Ltd Float bowl hight?
  • DBICK666
  • DBICK666's Avatar Topic Author
  • 1983 kz750 ltd f-1 (shaft)
25 Aug 2013 21:00
#603056
does anyone know the float bowl hight for 1983 kz750f ltd keihin cv stock carbs
  • Johanu
  • Johanu's Avatar
Re: 1983 kz750f Ltd Float bowl hight?
25 Aug 2013 21:10 - 25 Aug 2013 21:12
#603058
disregard
Last edit: 25 Aug 2013 21:12 by Johanu. Reason: wrong answer
  • martin_csr
  • martin_csr's Avatar
26 Aug 2013 12:39 - 26 Aug 2013 15:00
#603134
I guess you mean the float height? For the chain drive models it's 18.6mm.
A more accurate measurement is to do the Service Fuel Level check using a gauge to check the actual fuel level (clear tubing method). For the chain drive models, it's 3.0mm +/- 1mm below the carburetor body.
Last edit: 26 Aug 2013 15:00 by martin_csr.
  • DBICK666
29 Aug 2013 20:15
#603793
sorry i need the shaft dive 1983 kz750 f shaft float hight
  • martin_csr
29 Aug 2013 21:38
#603809
I bet it's the same. The more accurate measurement is the Service Fuel Level check for check the fuel level in the carburetors. Sometimes the float measurement doesn't translate into a correct fuel level.
Genuine Kawasaki Factory Service Manual.
Search ebbaayy for KZ750 Shaft Manual. There are usually quite a few listed & one or two for relatively cheap.
  • DBICK666
29 Aug 2013 23:44
#603854
So if the fuel level doesn't match I need to adjust the float hight hight or lower? Also could having the wrong float hight cause the bike to rev high to red line?
  • OKC_Kent
  • OKC_Kent's Avatar
30 Aug 2013 14:27 - 30 Aug 2013 14:30
#603929
I have a shaft manual for the 83 KZ750F. I wish I could scan and post the page, it seems to have two measurements.
The Service fuel level says 0.5 +- 1mm. It doesn't say where it's measured from, but probably from the mating surface of the bowl and body.
The Float height measurement says 14 mm.The float height is measured from the Float bowl mating surface on the carburetor body, and you measure to the center of the float's bottom flat surface.
In my opinion, you do not depress the float while measuring this, let it set on the valve by it's own weight. The manual does not say this, just from my experience.
Cashion, OK
78 KZ650 B2 85,000+ miles
Last edit: 30 Aug 2013 14:30 by OKC_Kent. Reason: spelling
The following user(s) said Thank You: DBICK666
  • DBICK666
30 Aug 2013 16:01
#603945
Thanks I got a kz750 ltd shaft book boot it has only kz750n in it the carbs look the same the mesurementvin that says 21mm and An 18.6mm mesurement I'm not sure what the 18.6 measures thanks for the 750f mesurement no one seemed to be any help so thank you any other advise would be nice also. I got the bike running now with float hight at 21mm should I re adjust it to 14mm? The bike is running kind of hot would this change anything re adjusting the float hight???
  • OKC_Kent
  • OKC_Kent's Avatar
31 Aug 2013 00:03
#604058
I would set them at 14mm. This will allow more fuel in the bowl. I don't know if this will help it run cooler.
What are the jets in the carbs? My book says main jet is 100, needle jet is N426-O1B36, jet needle is N10C, pilot jet is #35, Main air jet is #60
Cashion, OK
