replacing jets 83' spectre
  • rcook52459
  • rcook52459's Avatar Topic Author
25 Aug 2013 19:38 - 25 Aug 2013 19:52
#603043
have 4 to 1 exhaust with k&n filter.when rejetting do I replace the main(primary)or main (secondary)or both?Keihin cv34 carbs.runs great until 7,000rpm's then just feels it's starving for fuel.thanks
1983 750 spectre,all stock almost 16,000 on it on 1980 Suzuki gs1000l
Last edit: 25 Aug 2013 19:52 by rcook52459.
  • JR
  • JR's Avatar
Re: replacing jets 83' spectre
25 Aug 2013 21:34
#603059
The secondary main should be the larger of the two. You might need a magnifying glass to see the number stamped on it - either on the top or the side. Replacing that one had most impact when I played with carbs on my 1980 750/4. Not totally sure what jets are in the spectre carbs but thinking the principle should be the same
  • rcook52459
25 Aug 2013 22:52 - 25 Aug 2013 22:52
#603070
pretty much the same carb,but smaller jet sizes.thank you
Last edit: 25 Aug 2013 22:52 by rcook52459.
