Hacked petcock question
  • david-b
  • david-b's Avatar Topic Author
  • I am THAT guy
21 Aug 2013 23:26
#602551
As some of you may know, the previous owner of my bike hacked up the petcock. The switch on it was taken off and it's a constant on flow. I've got an inline fuel valve on it to shut it off when not running.
I had the tank off today and cut some of the fuel line (was little too long) and was going to pull the stubby line and cap it off. I thought that was a vac port, since fuel flows from the other port. Is that right? Because when I pulled it off, fuel poured out! Again the PO hacked it up so I don't know what exactly he did, but this is worrying me a little. Am I wrong to think that there should be a vac line going there?
I guess the other question is, where can I buy a petcock, preferably new?
Attachment IMG_20130821_182038_782.jpg not found
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
  • Motor Head
  • Motor Head's Avatar
Re: Hacked petcock question
22 Aug 2013 00:01
#602555
That petcock looks bad, whats that silicone hanging out?
Yes that was supposed to be the Vacuum port to switch it automatically.
Time for another petcock, Feebay?
  • david-b
  • I am THAT guy
22 Aug 2013 00:20
#602560
Like I said, have no idea what the hell he was thinking. It looks like he took it apart, screwed it up internally and used gasket sealer to fix it all.
Has anyone tried the custom made ones on there on eBay? No vac lines and on, off, reserve switch.
/Dave
  • nickleo373
  • nickleo373's Avatar
22 Aug 2013 00:20
#602561
You probably won't find a new original petcock for you bike. You can buy a working used one on ebay or some people end up putting on an aftermarket petcock.
1981 KZ550C LTD
"If you ain't first, you're last"
  • david-b
  • I am THAT guy
22 Aug 2013 00:26
#602563
No eBay APP ID and/or Cert ID defined in Kunena configurationAftermarket... Like this?
/Dave
  • Motor Head
22 Aug 2013 00:34 - 22 Aug 2013 00:37
#602566
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHere is a used one
A brand New superseded one, newest # from Kawasaki
Last edit: 22 Aug 2013 00:37 by Motor Head.
  • nickleo373
22 Aug 2013 01:05
#602568
Yes that is an aftermarket petcock. There are some aftermarket ones on ebay with no vacuum lines and stuff. I try to stay away from that because the aftermarket stuff I've ordered in the past has been cheap Chinese crap that breaks way to easily
1981 KZ550C LTD
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
22 Aug 2013 09:51
#602602
I recently replaced my vacuum petcock with an aftermarket version from Z1...Apparently designed for Suzuki, but once I "reclocked" it(Removed fuel outlet plate on the back,rotated 180 degrees, and re-installed) it bolted right up, and cleared the frame. Working fine.I might go back at some point and try rebuilding the original, but for now, I'm flowing fuel, no leaks, no drips, no errors!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
  • martin_csr
  • martin_csr's Avatar
22 Aug 2013 11:03
#602610
The aftermarket Suzuki petcock from Z1Ent has a 44 mm bolt-hole spacing. His GPz might be 34mm.
With the Pingel-adapter-plate type you have to ream out the hole 2-4mm to accept the screen. sparks + fumes = boom.
A late model Police bike petcock may fit -->> those models are included in the cross-reference-supersession info for the 82 GPz750 petcock. 51023-1375 is listed Active at Kawasaki.com.
KZR topic - Manual fuel valve option
  • Grumpy Ole Artist
22 Aug 2013 11:54
#602620
I could certainly be wrong, (I'm better when I read more carefully! LOL! )but I was told the police bike factory petcock was a replacement for mine, which is 44mm spacing. Pretty pricey, so I didn't really consider it.
1978 KZ650 B2
