Petcock rebuild kit
  • geerbangr
  • geerbangr's Avatar Topic Author
Petcock rebuild kit
21 Aug 2013 17:00
#602496
I've looked at z1parts.net and z1enterprise for a petcock rebuild kit for my 1978 kz1000A2 and couldn't find one there. Any ideas where I can pick up one ??
1978 KZ 1000
I go by Jason
Re: Petcock rebuild kit
21 Aug 2013 18:52 - 21 Aug 2013 18:53
#602526
I don't know where to get a kit, but you can buy all the pieces separately.
Attachment 00001_2013-08-21.jpg not found
The parts listed below as "Active" are still available so any online or local Kawasaki dealer can get them. The other 2 parts are available at:
www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
14 43058-1001 "0" RING ACTIVE
19 16126-1011 DIAPHRAGM VALVE ASSY
18 92081-1054 SPRING,DIAPHRAGM
20 92055-1068 "0" RING,DIAPHRAGm ACTIVE
21 11009-1044 GASKET,FUEL TAP ACTIVE
Last edit: 21 Aug 2013 18:53 by 650ed.
  • Gary - K7GLD
  • Gary - K7GLD's Avatar
  • 1983 1100LTD
21 Aug 2013 21:45
#602537
Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
21 Aug 2013 22:34
#602544
I love eBay, but I don't think any of those kits say they are for the 1978 KZ1000-A2. Ed
  • geerbangr
22 Aug 2013 02:08
#602572
That was my issue on eBay nothing says specific 1978 KZ1000 A2. I don't have the money to be wasting on the wrong parts.
650ed where did you find that parts breakdown ?
1978 KZ 1000
I go by Jason
22 Aug 2013 07:43
#602585
That's from Kawasaki.com.
If you go to Kawasaki.com on left side put cursor over "Owner Information" then on drop down menu click on "Parts Diagrams." The click "Continue" next to "Motorcycles" and click on model/year/etc. on drop down. Once you get the list of parts for your bike you can click on the category of parts - such as "Air Cleaner" and you will see a diagram of all the parts for that category. Then when you click on an actual part number on the list under the diagram it will say if the Item Status is "Active." If it is “Active” Kawasaki still sells the part through dealers. Also, at that little page you can click on the yellow highlighted question mark for a cross reference of which bikes share that part or click on the red highlighted S to see earlier part numbers for the same part. Ed
  • martin_csr
  • martin_csr's Avatar
22 Aug 2013 11:10 - 22 Aug 2013 11:11
#602612
Measure the bolt-hole spacing. It's probably either 44mm or 34mm.
If 44mm, Z1Enterprises.com has an aftermarket Suzuki vacuum petcock that might work.
This may not be much help... From Kawasakai.com for the 1978 KZ1000-A2:
51023-1375 TAP ASSY,FUEL
Model (8):
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-C1 (Police 1000) (1978)
KZ1000-C1A (Police 1000) (1978)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
Last edit: 22 Aug 2013 11:11 by martin_csr.
22 Aug 2013 12:36 - 22 Aug 2013 12:37
#602627
geerbangr wrote: That was my issue on eBay nothing says specific 1978 KZ1000 A2. I don't have the money to be wasting on the wrong parts....
+1 !
Be sure to double check part numbers. Here's what I see for pricing:
14 43058-1001 "0" RING ACTIVE $5.69
19 16126-1011 DIAPHRAGM VALVE ASSY $18.11
18 92081-1054 SPRING,DIAPHRAGM $2.83
20 92055-1068 "0" RING,DIAPHRAGM ACTIVE $13.05
21 11009-1044 GASKET,FUEL TAP ACTIVE $6.98
TOTAL COST (not including shipping) $46.66
Prices for ACTIVE parts from Partzilla
Prices for obsolete parts from www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
Last edit: 22 Aug 2013 12:37 by 650ed.
  • Gary - K7GLD
  • 1983 1100LTD
22 Aug 2013 16:19
#602657
Takes patience sometimes to find that exact match, or a usable interchange - here's another possibility:
www.oldbikebarn.com/Kawasaki-KZ1000-Petc...it?sc=2&category=185
John Day area - Eastern Oregon
Restored 1983 Kawasaki 1100LTD
22 Aug 2013 18:04
#602675
Gary - K7GLD wrote: Takes patience sometimes to find that exact match, or a usable interchange - here's another possibility:
I believe the issue is that he needs a kit for a 1978 kz1000A2 petcock. Unfortunately, the one in the link doesn't list that as one of the compatible models. Ed
  • Gary - K7GLD
  • 1983 1100LTD
23 Aug 2013 15:05 - 23 Aug 2013 15:39
#602795
Perhaps - but since they DO supply a large cross section of petcock rebuild kits, might be worth checking with them more directly to see if they DO offer the specific one for that bike...
Is that model bike REALLY that unique as to petcock design, that it was the ONLY year/model to use that specific petcock? :huh:
Last edit: 23 Aug 2013 15:39 by Gary - K7GLD.
23 Aug 2013 16:23 - 23 Aug 2013 16:24
#602800
It was not the only model to use that petcock. According to Kawasaki.com the ones in the list below all used the same petcock. It really makes one wonder why the aftermarket kits aren't available (or if available, are so hard to find) for those models. Ed
Last edit: 23 Aug 2013 16:24 by 650ed.
