Vac line on carb and airbox ?
  • david-b
  • david-b's Avatar Topic Author
  • I am THAT guy
20 Aug 2013 22:41
#602383
Hey all;
Quick questions. I got a stock airbox finally and was installing it and realized that there's 2 lines on the carbs that aren't going anywhere or capped. I've got the vac lines on each carb blocked, but where do the 2 inbetween 1+2 and 3+4 go?!
Attachment IMG_20130820_190427_632.jpg not found
Pic shows what I'm talking about. Where does this line go? This is probably what's causing some issues.
Second question... How in the HELL do you install the stock airbox on these bad boys? Literally worked on it for an hour today and threw in the towel. I took out the tank, carbs, and the seat and pushed all the wires and harnesses back. Right now I've got the carbs wedged between the airbox and motor, but the little rubber pods on the airbox have half popped inside the box.. HUGE pain in the ass. Any tips?
I appreciate all the help as always!
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
  • nickleo373
  • nickleo373's Avatar
Re: Vac line on carb and airbox ?
20 Aug 2013 22:46
#602384
I believe those hoses are fuel overflow tubes that should be routed to the ground. When installing carbs to your airbox it helps if you have new airbox boots that can easily be manipulated. Roll the boots over each other and it will free up enough room to get your carbs into the intake boots. Once the intake side is secured you can unroll your airbox boots and secure them to the other side of your carbs
1981 KZ550C LTD
"If you ain't first, you're last"
  • nickleo373
20 Aug 2013 22:47
#602385
Err actually maybe not fuel overflow hoses. I was thinking of another set of carbs sorry
1981 KZ550C LTD
  • kzz1king
  • kzz1king's Avatar
20 Aug 2013 23:04
#602391
Vents I believe.
Home built KZ1000 turbo setup
  • koolaid_kid
  • koolaid_kid's Avatar
21 Aug 2013 00:12
#602402
kzz1king wrote: Vents I believe.
Yes, those are vent hoses. They should be routed down between the engine and the frame/swingarm since you have the stock airbox installed. If you had pods, they should be left without hoses. (Just an FYI.)
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • david-b
  • I am THAT guy
21 Aug 2013 09:21
#602432
I thought those had to be left alone for a reason but couldn't remember and searching, couldn't find why they were still open. I had pods, which explains why they were just there.
I'll try the airbox again tonight. The roll-over idea is a good one. New ones would be a ton better, but we'll see how these work out.
/Dave
  • nickleo373
21 Aug 2013 14:12
#602472
If you have older boots I found it worked better to boil them and immediately fold them. It definitely wasn't easy but with a lot of patience it got the job done
1981 KZ550C LTD
  • martin_csr
  • martin_csr's Avatar
21 Aug 2013 16:45 - 21 Aug 2013 16:46
#602489
david-b wrote: I thought those had to be left alone for a reason but couldn't remember and searching, couldn't find why they were still open. I had pods, which explains why they were just there.
Even w pod filters, I would install vent tubing to keep water & road grit from getting into the carburetors.
As for the airbox, new ducts may be available from the dealer or Z1Enterprises.com. Soft pliable rubber makes installation much easier.
Last edit: 21 Aug 2013 16:46 by martin_csr.
  • david-b
  • I am THAT guy
21 Aug 2013 23:19
#602550
Thanks for all the help and tips. Went back to it with a clear head and fresh day and got the airbox on. Ended up pushing all the rubber intake boots inside the airbox some to give alittle more room. Left enough space where I was able to push the carbs into their holders and then push the rubber boots from inside the airbox out. Worked well, just took a little patience. Didn't have a chance to take her for a spin, but the idle was a lot better.
Attachment IMG_20130821_183409_336.jpg not found
Thanks again!
/Dave
