- Thank you received: 2
dies on full throttle
- pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
- pburnhamb
1976 kz900
1977 xs650
- pburnhamb
1976 kz900
1977 xs650
- nickleo373
- Thank you received: 33
1981 KZ550C LTD
"If you ain't first, you're last"
- koolaid_kid
- Thank you received: 99
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- pburnhamb
1976 kz900
1977 xs650
- nickleo373
1981 KZ550C LTD
- Thank you received: 2098
pburnhamb wrote: ... will start and idle perfectly/normal. I can rev it up a few times in neutral but on the 4th time or so it boggs down....
Insufficient valve clearances may also produce these symptoms (where cold engine seems to run okay, until it gets warmer, which reduces valve clearances).
- Mutz
Attachment 20130825_221410.jpg not found
Attachment 20130825_221454.jpg not found
- Mutz
Are the jets stock? I take your not running stock
Air filter box.
- pburnhamb
1976 kz900
1977 xs650
