kz550 petcock on kz650
  • tiedyed
  • tiedyed's Avatar Topic Author
19 Aug 2013 23:44
#602244
hey guys, just bought my first motorcycle (kz650b1) for $325 at an antique shop and i got it home to find that the petcock had been robbed off the tank. Upon searching for a replacement on ebay/google shop i have only found kz650 petcocks for $70-100, ebay has some kz550 petcocks that look like a 44mm gap for about $15 and im wondering if this will fit my tank? i have researched petcock replacement and found the adapter plate and 3/8ths fuel valve to be an alright solution. but my question is, will the kz550 petcock fit my tank? or should i just save my pennies and buy an adapter plate and a pingel?
by the way this is my first post in the forum. HEY DUDES!!!!!!
1978 kz650c2 superbike bars stock otherwise.
1977 kz650b1 parts bike with a huge wiring mess...
  • martin_csr
  • martin_csr's Avatar
Re: kz550 petcock on kz650
20 Aug 2013 09:37
#602278
I don't know if a 550 petcock will fit. Some (most?) 80s models have a 34mm bolt-hole spacing.
Z1Enterprises.com sells an aftermarket Suzuki vacuum petcock that should fit your bike.
For reference Z1Ent has a fuel valve info page.
As for a Pingel, you'll have to ream out the tank hole 2-4mm for the fuel valve screen -->>
..............................................................................................................................sparks + gasoline fumes = BOOM.
  • CoolerKing
  • CoolerKing's Avatar
20 Aug 2013 16:52
#602337
I don't know about the KZ550 petcock but I just bought this one:
www.z1enterprises.com/ItemDetails.aspx?item=KL18-4358
it's a common fix over on kz650.info
forums.kz650.info/index.php?topic=1221.0
if you end up going with the cheap one and it works, let us know!
1978 KZ650-C2
1976 KZ400D-3 (sold)
  • daveruckel
  • daveruckel's Avatar
20 Aug 2013 17:56
#602346
You might try z1parts.net
Just bought on for my 77 KZ1000 for $49. Suppose to be a factory replica replacement. I hope it works better than the cheap replacement that came with my bike that didn't last 7 miles before it started coming apart.
Dave Ruckel
1977 KZ1000
  • tiedyed
20 Aug 2013 18:34
#602353
i think the suzuki one from z1 will be the one i end up going with. thankyou, also for introducing me to kz650.info.
