- Thank you received: 33
float height adjustment
- nickleo373
19 Aug 2013 17:20 #602169
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
float height adjustment was created by nickleo373
Hey everyone.
Just adjusted my float heights to stop my carbs from leaking into my crankcase. I put the carbs back on the bike and set it to prime and no fuel is flowing. It worked when the carbs weren't attached to the bike but nothing will flow now. I disconnected the fuel hose from the carbs and it flows on the prime setting so it isn't the petcock. Any ideas?
1981 KZ550C LTD
- koolaid_kid
- Thank you received: 99
19 Aug 2013 17:38 #602171
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic float height adjustment
It sounds like you need to address the float height adjustment once again. It happens to the best of us.
1983 GPz 750
The following user(s) said Thank You: nickleo373
- Spectre1982
20 Aug 2013 09:42 #602280
by Spectre1982
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
Replied by Spectre1982 on topic float height adjustment
You probably bent the tab on the float too much. The valve needle is closing when you put the bowl back on.
1978 Kawasaki KZ200
- Thank you received: 1656
20 Aug 2013 10:16 #602291
by martin_csr
Replied by martin_csr on topic float height adjustment
Did you do the Service Fuel Level Check? ... to make sure the fuel level in each carburetor is correct?
- nickleo373
20 Aug 2013 14:11 #602321
by nickleo373
1981 KZ550C LTD
Replied by nickleo373 on topic float height adjustment
I had it set too high before to the point where it was spilling over into the intake manifolds and airbox. I'm not exactly sure where I need to measure from to get the correct heights. Does anyone know a specific height for an 81 kz550 with tk22 carbs? My clymer manual doesn't mention a specific number
1981 KZ550C LTD
20 Aug 2013 15:13 #602330
by martin_csr
The actual spec number is in a table at the end of the chapter that has the service fuel level procedure. (3.5mm)
loudhvx has a lot of 550 info on his motorcycle stuff page -->> see links in his signature.
- nickleo373
20 Aug 2013 16:50 #602336
by nickleo373
1981 KZ550C LTD
Is that number the distance the tang is supposed to be bent?
1981 KZ550C LTD
20 Aug 2013 17:49 #602342
by martin_csr
No. Using a fuel gauge, the measurement is the fuel level in relation to the carb body.
The manual should have the specifics for doing the Service Fuel Level Check.
