Adjusting needle position on smoothbore 29's
  • Dice
  • Dice's Avatar Topic Author
18 Aug 2013 17:39
#602034
How do you get to the needles on 29 smoothbores to adjust their position? Any tricks to doing this someone that's done it can pass on? Thanks
1975 Z1B
  • Haybus
  • Haybus's Avatar
  • Big Al
Re: Adjusting needle position on smoothbore 29's
19 Aug 2013 03:16
#602090
Pull the carb rack off the bike. Remove the tops, the screw and plate holding the actuator shaft, the 5 bolts on the shaft, and slide the shaft out. Pull the slide and armature out and separate the armature from the slide by removing the 2 small screws holding it to the slide body. Takes about an hour to R&R and be back running.
Alan
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
  • Dice
19 Aug 2013 16:09
#602146
That sounds easier than I thought it might be. Thanks for the insight!
1975 Z1B
