Big vacuum difference 3 cyl around 20, one just 9.
  • car5car
  • car5car's Avatar Topic Author
  • Banned
  • Banned
16 Aug 2013 13:41
#601704
Good compression, I adjusted removed carbs, nothing changed. Checked manifolds, no leaks!
96 Yamaha Royal Star
82 Yamaha Virago 920
Re: Big vacuum difference 3 cyl around 20, one just 9.
16 Aug 2013 15:28
#601716
Does it improve when you adjust the carb sync screw to raise the slide? Also, have you checked the valve clearances? Ed
  • car5car
  • Banned
  • Banned
16 Aug 2013 16:41
#601723
I adjusted valves, all exhaust clearances were low, I switched shims and only needed 1 shim.
Compression is about 140 in problem cylinder.
I found air screw very tight, less than 1/4 out, adjusted it to 1 1/4 like book says, but it didn't change anything.
I removed pod filter from another cylinder, it didn't change vacuum in that cylinder (clogged filter check)
The only crazy idea is that carburator has hole in it sucking extra air (???????????)
16 Aug 2013 18:02 - 16 Aug 2013 18:04
#601740
Did you adjust the carb sync screw to raise or lower the slide to see if that changed the vacuum level? The sync screw is not the air screw. Ed
Last edit: 16 Aug 2013 18:04 by 650ed.
  • car5car
  • Banned
  • Banned
16 Aug 2013 20:17
#601753
I was trying to adjust it, it didn't work.
My last chance was cleaning "choke" system. I pulled out all plungers, cleaned everything, it didn't work.
16 Aug 2013 20:43
#601759
car5car wrote: I was trying to adjust it, it didn't work.
Sorry, I don't understand "it didn't work." Was there a problem with the locknut and/or the screw, or were you able to loosen the locknut and turn the screw but there was no change in vacuum? We are talking about the same screw, right? The one under the carb's top cap? Ed
  • car5car
  • Banned
  • Banned
16 Aug 2013 21:11 - 16 Aug 2013 22:37
#601762
I begun increasing vacuum in problem cylinder, it improved from 9 to 11, after that throttle valve touched bottom and begun rising 3 other valves, increasing idle.
Yes, screw under top cover.
Last edit: 16 Aug 2013 22:37 by car5car.
  • car5car
  • Banned
  • Banned
17 Aug 2013 15:54
#601858
Problem is solved!
I left vacuum port on 3rd carb open. (I thought, it was vent port, looks identical to vent ports on 2nd and 4th cyl.)
