KZ200 Float Height
- Spectre1982
KZ200 Float Height
14 Aug 2013 01:45
The carb on my KZ200 is leaking from the overflow tube. Anybody know the float height on a '78 KZ200? I will obviously adjust it down until it stops flooding over, but was wondering if anyone had the actual spec. I have the manual but didn't see it listed. Maybe I missed it. Thanks!! I'll do the clear tube test tomorrow.
The spark plug is carbon fouling.
1982 Kawasaki KZ750 Spectre
1978 Kawasaki KZ200
1985 Yamaha XV1000 Virago
(Avatar picture is from Alleycatscustoms.com)
1978 Kawasaki KZ200
Re: KZ200 Float Height
14 Aug 2013 10:26
The info is probably in the manual. Usually there's a service fuel level check & also a float height measurement. The float measurement doesn't necessarily translate into a correct fuel level.
The following user(s) said Thank You: Spectre1982
- Spectre1982
14 Aug 2013 10:43
Thanks, Martin. I'll look in the manual again. I know it won't be perfect, I just wanted the spec so I can get close and then adjust from there.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
- Spectre1982
14 Aug 2013 11:38 - 14 Aug 2013 11:42
Found the float height. 29.5 +/- 1 mm. Service level is 5 +/- 1 mm.
1978 Kawasaki KZ200
1978 Kawasaki KZ200
Last edit: 14 Aug 2013 11:42 by Spectre1982.
