mixing carbs
- Steely
11 Aug 2013 21:56 #600926
by Steely
mixing carbs was created by Steely
I know it's been done before and it may be a ridiculous question but can't you run different make and model carbs on different engines as long as it's appropriate? For example one 250cc twin to another 250cc twin
- Steely
11 Aug 2013 21:59 #600927
by Steely
Replied by Steely on topic mixing carbs
Reason being I have a 250cc twin that has no carbs. I'm thinking any carbs from a 250cc 2 cylinder should work. Or 2 carbs from a 500cc 4 cylinder
- jeffasaki
- Thank you received: 44
11 Aug 2013 22:25 #600929
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
Replied by jeffasaki on topic mixing carbs
while a carb may not be necessarily a carb
at the end of the day a carb is a carb
and should work or at least try and do its job :silly: :side: :silly: :side:
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Steely
11 Aug 2013 22:39 #600931
by Steely
That's what I figured. I mean I have 550 carbs for a 4 cylinder and a 250 2 cylinder. Why not use half the carbs and fire it up
- jeffasaki
11 Aug 2013 22:46 #600932
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
give er a try
probly work if ya plug the leaks from cutting em in half :dry: :silly: :blink: :sick:
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- jeffasaki
11 Aug 2013 22:54 #600934
by jeffasaki
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
actually ive dsone the same thing
it works fine
last time was on a 75 cb 360t
also done on a pukaha i mean crapaha
xt 500 slutaha
i did like having a rd 350 cuntaha
it works fine
xt 500 slutaha
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Steely
12 Aug 2013 00:53 #600956
by Steely
Good to know. I've got this Mish mash project I'm thinking of starting and it's good to know that
- slayer61
- KZR FLAG RELAY CARRIER #62
12 Aug 2013 13:19 #601020
by slayer61
Seems to me you have trouble pronouncing YA-MA-HA! :lol:
No trouble here!
Replied by slayer61 on topic mixing carbs
jeffasaki wrote: actually ive dsone the same thing
it works fine
xt 500 slutaha
No trouble here!
