- Thank you received: 1
28mm vents
- hill
- 78 kz1000
04 Aug 2013 02:46 #599783
by hill
28mm vents was created by hill
I'm running some 28mm carbs on my kz1000.Theres 2 vents ports on them.Im running a rubber type 900 air box instead of the hard plastic original box.If I plug the vents,the bike runs like crap.I feel like I'm sucking dirty air in.My engine is 1075 with 425 lift cams,& z1r valves.Maybe I need bigger carbs anyway.I think these carbs were from an early 900.Any help is apreciated.
- Thank you received: 2829
04 Aug 2013 08:28 - 04 Aug 2013 08:30 #599793
by 650ed
Replied by 650ed on topic 28mm vents
The vent tubes on the Mikuni carbs are not used to suck in any air. They allow air to escape the carb bowls as the bowls fill with fuel. The tubes are intended to exit into the open air. The ends on the ones on my KZ650 drop down into the top of the air filter so any fumes from the carb bowls are sucked into the engine. The air baffle on mine is shaped at the bottom to hold them in place. Ed
Attachment 00000_2013-08-04-2.jpg not found
Attachment 00001_2013-08-04.jpg not found
Last edit: 04 Aug 2013 08:30 by 650ed.
- Motor Head
- Thank you received: 391
04 Aug 2013 09:56 #599802
by Motor Head
Replied by Motor Head on topic 28mm vents
Even the tool bag and the rubber hold down look brand new on Eds bike.
- hill
- 78 kz1000
04 Aug 2013 11:15 #599810
by hill
Replied by hill on topic 28mm vents
Good info.I thought since it ran like crap when I plugged them,then they must be sucking air.I'll run me a couple hoses into the top off box.
