throttle cable
- poohbear
02 Aug 2013 23:10 #599616
by poohbear
throttle cable was created by poohbear
I have 78 kz650, and I got it with only one throttle cable. The one closes to you when your sitting on it is missing. What cable do I have to order? Or do they sell sets with both.
- Motor Head
- Thank you received: 391
02 Aug 2013 23:25 #599622
by Motor Head
Replied by Motor Head on topic throttle cable
Many only run the one cable. But you can order a replacement for the missing or both, plus lots more at z1enterprises.com They will have lots for your bike. Also there are many other places as well to get one from.
- Thank you received: 2829
03 Aug 2013 00:31 #599628
by 650ed
Replied by 650ed on topic throttle cable
PLEASE specify your bike's model. The 1978 KZ650 B2 & C2 take a different cable than the 1978 KZ650-D1. It really helps if you add your bike's year & model to your signature line. Ed
- poohbear
03 Aug 2013 12:25 #599680
by poohbear
Replied by poohbear on topic throttle cable
how do i figure out what modle of bike mine is?
- Thank you received: 1656
03 Aug 2013 13:06 - 03 Aug 2013 13:08 #599684
by martin_csr
Replied by martin_csr on topic throttle cable
Try checking the engine & frame number info at the
jarlef z650
site.
The B model has spoked wheels & a Rr drum brake. The C has cast alloy wheels & triple disks.
Last edit: 03 Aug 2013 13:08 by martin_csr.
- poohbear
03 Aug 2013 13:38 #599701
by poohbear
my bike must be a c modle then, it has trible disc brakes.
03 Aug 2013 13:54 #599707
by martin_csr
Check the info at the site I linked. The SR had triple disks as well.
- poohbear
03 Aug 2013 16:27 #599716
by poohbear
alright thank you. also motor head you said people run with only one cable? if so would that make the bike die at idel or am i just having carb problems?
03 Aug 2013 18:08 - 03 Aug 2013 18:11 #599726
by martin_csr
The bike dying is a separate issue from the throttle cables. The VM24 carburetors have an open cable & a close cable, -- each one moves when you twist the throttle. The closing cable is a safety feature to make sure the throttle slides close when you decelerate. The extra cable also serves as a spare in case the open cable breaks for whatever reason - just switch the cables.
You should lubricate the cables, particularly the ends where they usually break. The throttle grip end can get dry & gritty, causing binding, so the cable frays - kinda like bending a paper clip back n forth.
Be sure to lubricate the clutch cable as well, especially the lever end.
Last edit: 03 Aug 2013 18:11 by martin_csr.
03 Aug 2013 20:16 #599739
by 650ed
Just look at the VIN stamped in the steering neck. If the VIN starts with "KZ650C" it's a C. If it starts with "KZ650D" it's a D. Ed
poohbear wrote: how do i figure out what modle of bike mine is?
