Will a 83 kz 1100 Petcock fit 82 kz 1100
- swaluda
02 Aug 2013 20:27 #599586
by swaluda
Will a 83 kz 1100 Petcock fit 82 kz 1100 was created by swaluda
Got a line on one, but don't know if it'll work,,, Stan
- Thank you received: 2829
02 Aug 2013 21:21 - 02 Aug 2013 21:22 #599594
by 650ed
Replied by 650ed on topic Will a 83 kz 1100 Petcock fit 82 kz 1100
PLEASE add your bike's year and model to your signature line (not all KZ1100 models use the same parts), it makes it MUCH easier to help you.
According to Kawasaki.com the 1981 - 1983 KZ1100 shaft bikes use the same petcock.
Also, the 1982 & 1983 Spectre and a bunch of other bikes use a common petcock, but it is different than that of the Shaft models. Ed
Attachment 00000_2013-08-02.jpg not found
Attachment 00001_2013-08-02.jpg not found
Last edit: 02 Aug 2013 21:22 by 650ed.
- Motor Head
- Thank you received: 391
03 Aug 2013 00:10 #599626
by Motor Head
Replied by Motor Head on topic Will a 83 kz 1100 Petcock fit 82 kz 1100
z1enterprises has a complete rebuild kit:
www.z1enterprises.com/ItemDetails.aspx?i...f1000&item=KL18-2703
- havakaw
- Thank you received: 27
05 Aug 2013 22:09 #600009
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Replied by havakaw on topic Will a 83 kz 1100 Petcock fit 82 kz 1100
I used a NOS 750 petcock on my 1100.It seems like the only real difference is where the fuel outlets are pointed.As in off to the side or straight out.That's about it.
'80 KZ 750 LTD-H
