Petcock to Carb Vacum hose gets gas inside
- swaluda
31 Jul 2013 20:06 #599304
by swaluda
Petcock to Carb Vacum hose gets gas inside was created by swaluda
Its not much but I have clear tube and can see droplets in there at idle. Is that normal, probably not. What should I look for to remedy this aboration.....Hmmm Stan, but we're getting there, one bite at a time
- Thank you received: 2829
31 Jul 2013 21:17 - 31 Jul 2013 21:17 #599318
by 650ed
Replied by 650ed on topic Petcock to Carb Vacum hose gets gas inside
The diaphragm inside the petcock may have a small hole or leak. You may want to take a look and replace or repair diaphragm if you find a hole. Ed
Last edit: 31 Jul 2013 21:17 by 650ed.
- Thank you received: 2098
31 Jul 2013 23:01 #599346
by Patton
Replied by Patton on topic Petcock to Carb Vacum hose gets gas inside
Z1 Enterprises probably carries the necessary petcock repair kit.
- P21
- Thank you received: 34
31 Jul 2013 23:39 #599352
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic Petcock to Carb Vacum hose gets gas inside
i will 2nd that
- swaluda
01 Aug 2013 09:21 #599386
by swaluda
Replied by swaluda on topic Petcock to Carb Vacum hose gets gas inside
Got one ordered from Darkhorse.
