Thought i had them right, but #2 wont respond to
- swaluda
31 Jul 2013 18:01 - 31 Jul 2013 18:02 #599272
by swaluda
Thought i had them right, but #2 wont respond to was created by swaluda
Number 2 carb wont respond when I adjust the air fuel screw and I need to choke it to start 5 minutes after I shut down all warmed up. Slight hesitation 0 to 1/8 throttle, after 1/8 throttle it seems to run fine. Number 2 plug is slightly carboned and the other 3 plugs are a light brown color. Thinkin the #2 carb has a blocked passage between the main and pilot jet. Cleaned the reed valves ( real dirty ), cleaned and re gapped the plugs to 7-8 mm. Tryin to fiqure out how to take off the timming advancer but that's a different post,,,, Thanks Stan 82 kawa 1100 d2 spectre
Last edit: 31 Jul 2013 18:02 by swaluda. Reason: add info
- Thank you received: 2098
31 Jul 2013 22:46 #599340
by Patton
Replied by Patton on topic Thought i had them right, but #2 wont respond to
Here's one approach to clearing the tiny passageway, whereby fuel mixture may enter the carb bore.
