How do i take off the timing advancer on my 82---
- swaluda
31 Jul 2013 17:44 - 31 Jul 2013 17:46 #599270
by swaluda
How do i take off the timing advancer on my 82--- was created by swaluda
I want to clean and grease the timing advancer. I took off the side cover and saw 2 magnetic pickups 180 degrees apart from one another. There a bolt between them. When I turn it the crank spins??????????? Hmmm,,,,,Stan 82 Kawa 1100 d2 spectre
Last edit: 31 Jul 2013 17:46 by swaluda. Reason: add info
- slayer61
- KZR FLAG RELAY CARRIER #62
31 Jul 2013 18:51 #599287
by slayer61
Replied by slayer61 on topic How do i take off the timing advancer on my 82---
Cool, you're under the right cover! That's a good start.
Mark exactly where the pick-up plate is mounted, and remove it, leaving the wires attached. Under the pick-up plate you'll find the advance mechanism. Springs and weights etc. clean, clean, clean, and lubricate. Now as Clymer says, "Installation is the reverse of disassembly!"
Good luck, Paul
Good luck, Paul
The following user(s) said Thank You: swaluda
- Thank you received: 1656
31 Jul 2013 19:20 #599290
by martin_csr
Replied by martin_csr on topic How do i take off the timing advancer on my 82---
After removing the pulsing coil, put a 17mm wrench on the crankshaft nut & remove the inner timing advancer bolt.
In the future whenever you have to turn the crankshaft, do so by using the big nut, not the advancer bolt.
The following user(s) said Thank You: nitrokrumpt
- Motor Head
- Thank you received: 391
31 Jul 2013 21:56 #599325
by Motor Head
Replied by Motor Head on topic How do i take off the timing advancer on my 82---
On yours, the three screws which hold the plate with the pick-up coils can only bolt back in one spot, unless someone slotted it. One hole, the top one, will locate it.
The advancer comes off like posted,. Then the inner hub and the outer rotor come apart. This means taking the springs and weights off. Then the clip on the end. Now this is where you either need to look at the factory marks or make some that you can see easy. Because you can easily reassemble 180 out.
You will see when the two are separated, the grove and bore that needs cleaning and then lubing. I use a Bosch Distributor special high temp grease.
- swaluda
01 Aug 2013 09:33 #599388
by swaluda
Replied by swaluda on topic How do i take off the timing advancer on my 82---
i'm going for it, wont get done just looking at it. One bite at a time.. Thanks guys Stan
