setting float level with clear tube.
- swaluda
29 Jul 2013 22:59 #599010
by swaluda
setting float level with clear tube. was created by swaluda
The book says 3 mil plus or minus one from the bottom of the carb body. Theres a 2 mil difference to where the gasket seats. Should one measure from where the gasket seats, or the real bottom of the carb body, which is 2 mil below where the gasket seats. Thanks Stan
- Thank you received: 2829
29 Jul 2013 23:03 #599014
by 650ed
Replied by 650ed on topic setting float level with clear tube.
maybe this will help. Ed
Attachment 00000_2013-07-29-3.jpg not found
- Motor Head
- Thank you received: 391
29 Jul 2013 23:05 #599015
by Motor Head
Replied by Motor Head on topic setting float level with clear tube.
Just like it says, the bottom of the carb body, which is the gasket surface.
- swaluda
30 Jul 2013 07:45 #599043
by swaluda
Replied by swaluda on topic setting float level with clear tube.
Ed, Motor, Thanks Guys,,,,Stan
- Thank you received: 1656
30 Jul 2013 09:51 - 30 Jul 2013 09:51 #599055
by martin_csr
Replied by martin_csr on topic setting float level with clear tube.
The gasket surface stuff is when you check the float height w the carburetors dry, upside down, & with the carb bowls removed - the measurement is taken from the gasket surface (gasket removed).
So you can't really use the gasket surface when checking the actual fuel level... unless you have x-ray vision or something.
just showing the gasket surface.
Last edit: 30 Jul 2013 09:51 by martin_csr.
- Thank you received: 2098
30 Jul 2013 10:46 - 30 Jul 2013 11:24 #599063
by Patton
The 2 mil is presumably width of the "lip" surrounding the gasket area, whereby the bottom edge of the lip is lower than the gasket area.
Text from both the Z1~KZ900 FSM and 1977~1979 KZ1000 FSM reads "...from the edge of the carburetor body."
Which imo should probably be interpreted as measuring from bottom edge of the lip, as opposed to measuring from the gasket surface area.
And concurs with martin_csr.
Replied by Patton on topic setting float level with clear tube.
swaluda wrote: The book says 3 mil plus or minus one from the bottom of the carb body. Theres a 2 mil difference to where the gasket seats. Should one measure from where the gasket seats, or the real bottom of the carb body, which is 2 mil below where the gasket seats. Thanks Stan
Attachment floatbowlinsideviewedgecleartube.jpg not found
Attachment cleartubelip.jpg not found
Last edit: 30 Jul 2013 11:24 by Patton.
- KZQ
- Administrator
- Thank you received: 1415
30 Jul 2013 11:14 #599068
by KZQ
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Replied by KZQ on topic setting float level with clear tube.
I just went through this process on my 1300. I didn't use the special tool just a piece of clear tubing that would fit over the drain. Actually, I had problems with the size of the tubing because every time I opened the drain the fuel would flow but would leave a bubble of air up near the carb. depending on the size of the bubble the reading would vary widely. Eventually I used two sizes of tubing, one that fit over the drain and a smaller tube that fit inside the first tube. When fitted with the smaller tube the fuel would force all the air ahead of the fuel and I finally started getting repeatable measurements.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
