- Thank you received: 16
synch problems - no vac on #3
- KZ250LTD
27 Jul 2013 22:39 #598633
by KZ250LTD
79 KZ1000ST
Past:
Many.
synch problems - no vac on #3 was created by KZ250LTD
79 kz1000st
Bike wasn't running right last year, pulled carbs off today to move needle clip and clean them. Went to synchronize and i get no vacuum on #3. Only way to get the other three up to ~20 is to back #3 screw right off. As soon as i start to screw it down again it kills everything. If i synchronized all four to #3 none even read on the gauge. Thought it might be a dead cyl but it has 120 psi and burns fuel just fine (looking through colortune ). Any help is appreciated.
79 KZ1000ST
Past:
Many.
- KZ250LTD
27 Jul 2013 23:58 - 27 Jul 2013 23:58 #598645
by KZ250LTD
Last edit: 27 Jul 2013 23:58 by KZ250LTD.
- Thank you received: 2098
28 Jul 2013 00:24 #598649
by Patton
Replied by Patton on topic synch problems - no vac on #3
Valve clearances within specs?
Water spray test on header pipes to confirm combustion?
