- Thank you received: 3
kz750 e/h jetting
- gixxerkidd03
25 Jul 2013 21:26 #598279
by gixxerkidd03
1981 KZ750e
kz750 e/h jetting was created by gixxerkidd03
i just got my dyno jet kit for my kz750e/h carbs. it wants me to drill out the slidelift hole. do i drill both slide lift hole(s) since mine seem to havetwo holes? i hope thats not a stupid question. thanks guys!
1981 KZ750e
- gixxerkidd03
25 Jul 2013 21:42 #598281
by gixxerkidd03
1981 KZ750e
Replied by gixxerkidd03 on topic kz750 e/h jetting
i have dyno jet kit 2102 and my carbs are a set of keihins
1981 KZ750e
- Jrbrownie00
- Thank you received: 9
25 Jul 2013 21:53 #598283
by Jrbrownie00
82' kz750 ltd.
Replied by Jrbrownie00 on topic kz750 e/h jetting
I did. Pretty sure the instructions say holes?
82' kz750 ltd.
- Motor Head
- Thank you received: 391
25 Jul 2013 22:00 #598285
by Motor Head
Replied by Motor Head on topic kz750 e/h jetting
The holes would be on the engine vacuum side, and not where the needle goes in. I don't have there kit, but would say if there is more than one hole on the engine side of the slide, and the kit instruction says "Holes", then drilling both would sound correct. Give them a phone call to verify before drilling to verify, before drilling incorrectly.
- koolaid_kid
- Thank you received: 99
25 Jul 2013 22:13 - 25 Jul 2013 22:14 #598288
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic kz750 e/h jetting
I just read their instructions. The picture shows two holes in the slides. One is in the center where the needle goes. The other one already exists to the side of the needle. Use the drill bit DD# 31 to ENLARGE the existing one on the side of the needle, do not make a new hole.
For informational purposes only, this allows the slides to lift faster.
1983 GPz 750
Last edit: 25 Jul 2013 22:14 by koolaid_kid.
- gixxerkidd03
26 Jul 2013 00:28 #598318
by gixxerkidd03
any issues? sounds like you dont have any problems. i surely dont plan to drill any extra holes. im having an issue with my choke return spring, it just seems to weak to return close. :evil:
1981 KZ750e
Jrbrownie00 wrote: I did. Pretty sure the instructions say holes?
1981 KZ750e
- Jrbrownie00
26 Jul 2013 09:36 #598352
by Jrbrownie00
82' kz750 ltd.
I have pods from Z1, a MAC4-1 and I went stage 3 with the Dynojet kit and I'm pretty happy. I didn't notice a difference between the 130 and 136 jet but I'm having a problem with either a fuel cut or ignition after 6000rpm. It was present before pods and jetting so don't be leery. I should have fixed it before doing either but I'm impatient and chasing an ignition or voltage problem is time consuming.
You will need to sync the cards with either gauges or the home made method. It ran good with just a bench sync but it runs awesome with the legit sync.
82' kz750 ltd.
