- Thank you received: 29
Air box tops
- Del_Herring
24 Jul 2013 17:29 #598098
by Del_Herring
1983 KZ750-N2 Spectre
Air box tops was created by Del_Herring
So, my air box top looks about like this:
So it won't attach to the airbox anymore. It seems like most of what I find on e-bay is in similar condition, and it's not an active part according to the Kawasaki site.
Does anyone have any clever fixes to keep that from leaking. Otherwise, the air just kind of goes around the filter without needing to go through it, which may be part or all of what's contributing to the lean condition I'm getting (I got plenty of other problems too, but one at a time).
Attachment airboxtop.jpg not found
- Thank you received: 2829
24 Jul 2013 17:59 #598100
by 650ed
Replied by 650ed on topic Air box tops
You may want to clean it well and then try some super-glue. That stuff may do the trick. Ed
- uncle nick
- Thank you received: 5
25 Jul 2013 18:35 #598250
by uncle nick
1981 KZ650 CSR
Replied by uncle nick on topic Air box tops
I'd try super glue or better still Araldite maybe even silicon
If you don't fancy that there's one on eBay, bit.ly/13IJxCJ
Good luck
Good luck
1981 KZ650 CSR
- Del_Herring
26 Jul 2013 11:19 #598376
by Del_Herring
Replied by Del_Herring on topic Air box tops
Oh well. I was hoping there'd be a compatible part from another bike or something. Was trying to avoid buying a whole new airbox just to get the one piece, but I might have to. I'll try gluing things together if I can find the part of the top that has the threads, it seems to have wandered off.
- Thank you received: 1656
26 Jul 2013 11:49 #598384
by martin_csr
Replied by martin_csr on topic Air box tops
I'm pretty sure all of the KZ650s & 750-4s use the same airbox cap. Kawasaki dealers are supposed to have some sort of nationwide search for finding parts that the individual dealers happen to have in stock (that may be otherwise listed as NLA). So, if there's a helpful Kaw dealer near you, maybe someone there can do some checking for you?
- uncle nick
26 Jul 2013 12:32 #598390
by uncle nick
1981 KZ650 CSR
it's shown in my parts manual as Part Number 11012-069 and the H1,H2 and H3 all have the same part number.
A quick look on Google and SpeedSupplies.com lists the cap for $12.50
www.speedsupplies.com/parts/kawasaki-11012-069.htm
You may find it cheaper if you try a few other links.
Good luck and happy hunting!
1981 KZ650 CSR
26 Jul 2013 22:23 #598463
by 650ed
Speedsupplies won't have it because according to Kawasaki.com it is no longer an "Active" part. Speedsupplies lists everything, but they include a note that states:
"Parts availability is subject to that of the manufacturer's stock. No New Old Stock items available." Ed
- uncle nick
26 Jul 2013 22:50 #598471
by uncle nick
1981 KZ650 CSR
I hadn't realised that, thanks for pointing it out Ed.
I looked at some of the other links, Partzilla don't have one in stock but list the other models that used it:
www.partzilla.com/parts/detail/kawasaki/KP-11012-069.html
These list it for sale, hopefully one can help:
www.sbmotor.com/OEMpartfinder.htm?vcc=Mo...2A-1978%2f070076D-32
www.teamwinnebagoland.com/OEMpartfinder....-B1-1977%2f070076D-3
www.fastoysracing.com/OEMpartfinder.htm#...H2-1982%2f070087J-11
www.allemancycleplex.net/OEMpartfinder.h...F1-1980%2f070055C-14
www.cycledepot.com/OEMpartfinder.htm#%2f...-A1-1984%2f080199B-6
Good luck!
Good luck!
1981 KZ650 CSR
- Beaner242
27 Jul 2013 00:47 #598499
by Beaner242
1982 KZ1000K LTD Chopper
Replied by Beaner242 on topic Air box tops
I just used some JB weld clear epoxy to hold some stuff together. I guarantee it will hold that.
- Del_Herring
29 Jul 2013 10:43 #598880
by Del_Herring
Yup, I found listings for it, but they were usually listed as "out of stock," etc because it isn't active. I can't find the threaded portion of my top, so gluing it together might not be an option. And it's in pretty rough shape as a whole, looks like the guy overtightenned it a bunch, everything's cracked on it. I'll try checking with a dealer to see if they can find one. If not, I'll just have to buy a whole box, or wait around e-bay for a while until one shows up by itself. Not a huge deal compared to some of the other issues this thing has right now.
- uncle nick
29 Jul 2013 15:08 #598919
by uncle nick
1981 KZ650 CSR
Did u try the links I posted earlier?
They were listing as in stock. I tried adding to basket to make sure.
Good luck.
What else needs fixing?
Good luck.
1981 KZ650 CSR
29 Jul 2013 15:18 #598920
by martin_csr
Being able to add an item to a cart doesn't mean they have it or can get it. Some places will take your money, then tell you afterwards that the part is NLA.
