What would you do?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
What would you do?
24 Jul 2013 13:19 - 25 Jul 2013 11:07
#598064
I've re-jetted, raised the needle, and have the BS34's working well, but may want to upgrade at some point, and maintain the option of using the air box. I wonder what make/model and size carburetor would be the best choice to replace the BS34's, while keeping cost reasonable. I would rather find a used carburetor set on ebay, instead of buying new.
Would Smoothbores be the best choice?
I'd prefer to keep the stock single-cable throttle system, unless a push/pull replacement throttle unit is available with a start/kill switch, specifically designed to replace the original unit.
The KZ1100-A2 motor is stock. Upgrades to date include a V&H header/baffle (no glass wrap), and Dynatek 2000/Mini-coils, and misc. minor things. :)
1982 KZ1100-A2
Last edit: 25 Jul 2013 11:07 by daveo.
  • daveo
  • Premium Member
  • Premium Member
Re: What would you do?
25 Jul 2013 10:51 - 25 Jul 2013 11:10
#598191
HELP! :blink:
1982 KZ1100-A2
Last edit: 25 Jul 2013 11:10 by daveo.
  • koolaid_kid
  • koolaid_kid's Avatar
25 Jul 2013 12:29
#598198
You would be best served by staying with the BS34s. If you feel the need for more fuel, consider the DynoJet Stage 1 or Stage 3 kits instead. BTW, the Stage 3 kits have all the jets for doing the Stage 1 jetting, so you would be best served by just getting it while you are at it.
The smoothbores would be a step backward IMHO.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • daveo
  • Premium Member
  • Premium Member
25 Jul 2013 13:35 - 25 Jul 2013 16:50
#598203
koolaidkid
Its probably a lot to ask, but...
How effective are the Dynojet mods at enhancing engine performance throughout the range, and do they create any adverse tuning issues? With a kit installed, will acceleration be smoother, or will there be dramatic power surges as the throttle is opened and closed?
I want to run with the stock air box, so does that require a Dynojet Stage-2 setup? I only see Stage-3 in the 2310 Dynojet web instructions, and it appears that changes are limited to the main jet/needle, and vacuum slides.
Thanks
1982 KZ1100-A2
Last edit: 25 Jul 2013 16:50 by daveo.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
25 Jul 2013 15:50
#598215
I cant speak for the KoolAide Kid, but I used a dynajet kit on my Mrs's little GPZ. It has a Kerker 4-1 and always had a little stumble :( just off idle. The DJ kit has eliminated the stumble. :cheer: That's been my experience with them. Paul
  • daveo
  • Premium Member
  • Premium Member
25 Jul 2013 16:55
#598227
slayer61
Is Mrs's little GPZ an 1100? Was it a Stage-3 kit you installed?
1982 KZ1100-A2
  • koolaid_kid
25 Jul 2013 17:00
#598228
There is no Stage 2. Not sure why, but that is the way it is. There are many changes that it provides, mostly the needle. Its taper is far better than the stock needle, plus it is fully height adjustable, for fine tuning the needle. Also raising the diaphragm quicker and letting a bit more air in right off idle.
I have a Stage 3 in my GPz. It has pods and a pipe, which requires the Stage 3.
Tuning is the issue. I have a wideband, aka a sniffer, so I used it to dial in the carbs. If you do not have that luxury you have to do plug chops, which are quite tedious.
But I would never, ever go back to stock Mikuni parts.
The kits are around $125, a few sets of plugs, some patience and understanding of how the Mikuni CV carbs work, and you will be grinning from ear to ear.
1983 GPz 750
  • daveo
  • Premium Member
  • Premium Member
25 Jul 2013 17:05
#598229
Will use of the Stage-3 kit require changing over to pods, or can I still use the air box?
1982 KZ1100-A2
  • koolaid_kid
25 Jul 2013 17:05 - 25 Jul 2013 17:06
#598230
It doesn't really matter the size of the motor. The same is true across the board, for all brands with the Mikuni carbs, such as those off-brand Suzukis. :lol:
The Stage 3 kit contains the main jets required for a Stage 1 also.
Pods or a pipe, install the Stage 1 jets. Pods and a pipe, install the Stage 3, which is mainly changing the mains and retuning the needle.
1983 GPz 750
Last edit: 25 Jul 2013 17:06 by koolaid_kid.
  • daveo
  • Premium Member
  • Premium Member
25 Jul 2013 17:10
#598231
Now I'm starting to get excited...
1982 KZ1100-A2
  • 650mod
  • 650mod's Avatar
25 Jul 2013 17:30
#598235
I've got a stage 3 kit on my '78 650 with an overbore, pipe, and pods. It's made a huge difference in performance, especially when you hit into the upper range (with the needle taper being thinner). Pulls a lot smoother, with good response over the range. Agreed with what's been said- the stage 1 should be fine, but I'd get the stage 3 if you ever did any more mods to the bike.
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • koolaid_kid
25 Jul 2013 17:33
#598236
Getting the Stage 3 kit to begin with allows you to set the other parts aside. If you ever go to pods, just pull the box out, follow the instructions, retune, put the box back. The difference in price is minimal, if any at all.
1983 GPz 750
