carb simplification
- emead13
24 Jul 2013 07:36 #598022
by emead13
carb simplification was created by emead13
is their any vacuum line on the carb i can get rid of on a a4 kz550 just trying to run as little as possible...
- emead13
24 Jul 2013 07:43 #598023
by emead13
Replied by emead13 on topic carb simplification
- Thank you received: 2829
24 Jul 2013 09:08 - 24 Jul 2013 09:41 #598028
by 650ed
Replied by 650ed on topic carb simplification
If your bike has that "Clean Air System" with hoses going to the valve cover that can be blocked off. If you do a search on this site you will see how.
Also, if you have the vacuum operated petcock you can replace it with a manual petcock and cap that vacuum port on the carb.
Earlier KZ's (like mine) had no vacuum hoses at all coming from the carbs. The only hoses are the single fuel line, the 2 vent tubes, and the 4 overflow tubes. Ed
Last edit: 24 Jul 2013 09:41 by 650ed.
- Motor Head
- Thank you received: 391
24 Jul 2013 09:21 #598034
by Motor Head
Replied by Motor Head on topic carb simplification
The only vacuum hose that is needed is to the petcock. Or if you want to turn it to Prime for it to work, you could do away with it also. Now the Vent and drain hoses, those you should leave alone.
