wet plugs, complicated.
- cherokeekid58
23 Jul 2013 22:01 #597978
by cherokeekid58
Hahaha and i thought my JEEP addiction was bad; my Kz addiction is just as bad!!!
www.kzrider.com/filebase/cat_view/102-1982 ,
wet plugs, complicated. was created by cherokeekid58
I just put my engine back in my 82' kz750 ltd h3. I took the baffles out of the exhaust and it currently have just open carbs, no filters orbox. I started it to see if it ran ok after the re-build and it idles fine and runs quiet. My problem lies in the fact it seems its getting to much fuel. The plugs are soaked and it bogs down when you try to rev it. I know you have to re jet the carbs when you do an exhaust and filters. But mine seems to be the opposite. Is this even possible?
Cheers
Jason
Cheers
Jason
- koolaid_kid
- Thank you received: 99
26 Jul 2013 09:47 #598358
by koolaid_kid
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Replied by koolaid_kid on topic wet plugs, complicated.
There is absolutely no way that you can do anything with your engine in your condition. It is virtually impossible to get the jetting correct with no filters and no baffles.
Sorry, but you at least need to put K&N pods on the carbs. Then recheck and you will have some sort of a starting point.
Best of luck.
Best of luck.
1983 GPz 750
- Jrbrownie00
26 Jul 2013 09:50 #598359
by Jrbrownie00
82' kz750 ltd.
Replied by Jrbrownie00 on topic wet plugs, complicated.
MikeXS.net sells a knock off version the K&N's that I would have purchased before my z1 pods had I known. Try those out.
82' kz750 ltd.
- koolaid_kid
26 Jul 2013 11:24 #598377
by koolaid_kid
1983 GPz 750
It is actually
mikesxs.net
. You forgot the "s". Just to let you know.
I checked them out, they look pretty good, especially for that price.
You'll want to oil them with filter oil, be sure and pick that up also. Just don't over oil them, a common mistake with K&N users.
1983 GPz 750
- cherokeekid58
28 Jul 2013 22:57 #598802
by cherokeekid58
Replied by cherokeekid58 on topic wet plugs, complicated.
Thanks for the replys. I know I need pods before the tuning. I was curious as to what causes my condition. I'm taking it to a shop nearme that I absolutly trust 100%. They are gonna put it on the dyno with the pipe sniffer that reads air/fuel burn.
I ordered carb holders already so all my seals are tight with no vacuum leaks.
Cheers
Jason
Cheers
Jason
