bench sync.
- danpitts
23 Jul 2013 19:50 #597958
by danpitts
bench sync. was created by danpitts
can anyone tell me the procedure to bench sync. 24mm carbs on78 650 kz sr
- Thank you received: 2829
23 Jul 2013 20:20 - 23 Jul 2013 20:40 #597961
by 650ed
Replied by 650ed on topic bench sync.
Do you have a Kawasaki Service Manual? If not, you really should get one; no KZ owner should be without one. There is a full description of bench sync'ing and dynamic sync'ing in the manual. Keep in mind, the bench sync will only get you in the ballpark; you will still need to perform dynamic carb synchronization with the engine running. Ed
Attachment 00000_2013-07-23.jpg not found
Last edit: 23 Jul 2013 20:40 by 650ed.
The following user(s) said Thank You: danpitts
