I would like to thank KZR
- swaluda
23 Jul 2013 16:05 #597918
by swaluda
I would like to thank KZR was created by swaluda
Thank You Guys at KZR forum for your expertise. Motorhead, Pete1958 ,Cynjut. gd4now and Havakaw. It pleases me to say the 82Kaw 1100 d2 Spectre shaft drive is one mean SOB. I mean this sucker Screams. Couldn't have done it without you guys. Now I need to address the hairline Head Crack , or what ever it is that's leaving oil on my dag nabbin socks. As you recall, I rebuilt the carbs and needed advise on many issues. Thanks Again Guys,,,,,,Stan
- Del_Herring
- Thank you received: 29
23 Jul 2013 16:17 #597920
by Del_Herring
1983 KZ750-N2 Spectre
Replied by Del_Herring on topic I would like to thank KZR
I'm not sure what all you've done to this point, sounds like you've been busy. Can you tell where the leak is coming from? My spectre had a slight oil leak when I got it, and all I had to do was re-torque the head-nuts. The gaskets on these things can take a lot of abuse, so it ended up being ok. If you've actually got a crack it won't help, but it's an easy first check.
- swaluda
23 Jul 2013 17:22 #597932
by swaluda
Replied by swaluda on topic I would like to thank KZR
don't really know exactly where its leaking but tomorrow I will find it, Hoping for the best.....Stan
- Motor Head
- Thank you received: 391
24 Jul 2013 00:03 #597997
by Motor Head
Replied by Motor Head on topic I would like to thank KZR
Post up some real clear pictures.
